[petsc-users] iterative solver in PETSc on a multiprocessor computer
amrit poudel
amrit_pou at hotmail.com
Thu Sep 8 12:59:29 CDT 2011
After running my simulation multiple times on a multiprocessor computer I've just verified that using iterative solver (default gmres) in PETSc to solve a linear system of equations ( Cx=b) with more than 2 processors setting ALWAYS lead to erroneous result. Running identical code with identical setting except for the number of processors ( set this to 2) ALWAYS gives me correct result .
I am really not sure what is the point behind including iterative solvers if they result into erroneous result on a multiprocessor computer. The result I get from multiprocessor computer is a complete garbage, so I am really not talking about small percentage of error here. Also, if somebody could enlighten why the iterative solvers are error prone on multiprocessors that will be highly appreciated.
I am very hopeful that there is a way around to this problem, because PETSc is such a powerful and useful library that I really do not want to give up on this and start something else from scratch.
Would you think that a DIRECT SOLVER would circumvent this problem? My problem is that I have a very large system of equations and the size of a sparse coefficient matrix is huge ( > 1e+8). I assemble this matrix in MATLAB, write to a binary file, and read it in PETSc. So I really need to be able to solve this system of equations in a cluster of computers (which inherently has multiprocessors and distributed memory setting). Does this mean I am completely out of luck with PETSc's iterative solver package and the only hope for me is the direct solver? I do have MUMPS downloaded and compiled with PETSc, so I will give that a try and see what results I obtain, but I am really surprised that iterative solvers are no good in a large multiprocessor settings.
Any insights, suggestions/advice will be highly appreciated.
Thanks.
PS (I can attach my entire code, plots that compare the results obtained by solving Cx=b in 2 processors vs 12 or 6 processors if any body wants to take a look at it. I get garbage if I run iterative solver on 12 processors)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110908/48014bd2/attachment.htm>
