[petsc-users] petsc with slepc
Micheal Lysaght m.lysaght at qub.ac.uk
Wed Sep 7 05:38:31 CDT 2011
Dear PETSc team,
I am currently using PETSc with SLEPc to diagonalize a sparse Hermitian
matrix. I have had success with doing so, so long as I create the PETSc
matrix object using
MatCreateMPISBAIJ
with PETSC_DECIDE used for both the number of rows and columns.
Upon assembling the matrix object, I then call the relevant SLEPc EPS
routines (where the default Krylov Schur method is invoked)
Doing this, everything works fine and the correct eigenvalues are returned.
However, if I try to do the same thing with the difference that I decide
the number of rows and columns assigned to each MPI process during the
matrix creation, SLEPc returns an error message with regard to the
dimensions being used.
I have checked that the matrix object has the correct form and values by
viewing the matrix, so it is certainly assembled in the correct way
using PETSc.
My question is, can SLEPc handle matrices that are constructed according
to the users choice of the numbers of rows and columns assigned to each
MPI process. I realize that this would need to be accounted for in the
vector that is being multiplied into, but how do I get access to this
vector in SLEPc? Or do I even need to?
Any help or tips would be very much appreciated.
Best regards,
Michael Lysaght
Visiting Research Fellow,
CTAMOP,
Queen's University Belfast
