[petsc-users] compilation with mumps on Mac OS 10.6.8
Barry Smith
bsmith at mcs.anl.gov
Tue Sep 6 22:49:10 CDT 2011
On Sep 6, 2011, at 10:41 PM, Kyunghoon Lee wrote:
> Hi Barry,
> Thanks for the reply. I did install g95 through macports. (I could not find gfortran.) I wonder g95 can do the job for me.
g95 might work, give it a try. BTW: on Macs you don't need to provide blas/lapack with --download; Apple provides them on the system.
> Re SuperLU_Dist, all I know is I need mumps to deal with complex numbers.
SuperLU_Dist can also be used with complex numbers (at least with PETSc-dev/petsc-3.2)
> K. Lee.
> On Wed, Sep 7, 2011 at 11:21 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > p.s.
> > I do not need to compile petsc for FORTRAN.
> Sadly you do because the packages MUMPS uses are all Fortran.
> So you will need a real Fortran compiler (perhaps gfortran) and you will also need --download-blacs and you cannot use --download-c-blas-lapack with scalapack.
> Note you can use SuperLU_Dist instead of MUMPS without a Fortran compiler.
> Barry
> On Sep 6, 2011, at 10:17 PM, Kyunghoon Lee wrote:
> > Hello all,
> > I need to compile petsc with mumps. First I tried
> > ./configure --prefix=/Users/aeronova/Development/local/lib64/petsc/petsc-3.1-p8 --download-c-blas-lapack=1 —download-parmetis=1 --download-scalapack=1 --download-mumps=1
> > but I got the following message:
> > Fortran error! mpif.h could not be located at: []
> > So I included "-download-mpich=1," then I got the following:
> > Should request f-blas-lapack, not --download-c-blas-lapack=yes since you have a fortran compiler?
> > After that, I tried several options with/without --download-f-blas-lapack or --download-mpich=1, but none of them worked out. I'd appreciate it if someone can help me with this compilation problem with mumps.
> > Regards,
> > K. Lee.
> > p.s.
