[petsc-users] Still no luck
Tue Sep 6 22:46:35 CDT 2011
On Sep 6, 2011, at 10:22 PM, S V N Vishwanathan wrote:
> I updated my code to compile with the latest development branch and ran
> it. Now I get the following error:
    I think I see the problem. We fixed MatLoad() to handle the very large matrices with 64 bit indices but not the MatView().
    I have updated both the 3.2 release candidate and petsc-dev to handle this case. But you need to use Mecurial to get the updates and cannot use the tarball.
    If you have used Mecurial then all you need do is; hg pull; hg update; cd src/mat/impls/aij/mpi; make to update the libraries
    Please let me know if this does not resolve the problem.
   barry
> Writing data in binary format to /scratch/lustreA/v/vishy/temp/Binary/biclass/test.txt
> [0]PETSC ERROR: MatView_MPIAIJ_Binary() line 1369 in src/mat/impls/aij/mpi/mpiaij.c
> [0]PETSC ERROR: MatView_MPIAIJ_ASCIIorDraworSocket() line 1479 in src/mat/impls/aij/mpi/mpiaij.c
> [0]PETSC ERROR: MatView_MPIAIJ() line 1575 in src/mat/impls/aij/mpi/mpiaij.c
> [0]PETSC ERROR: MatView() line 755 in src/mat/interface/matrix.c
> [0]PETSC ERROR: main() line 93 in test.cpp
> application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
> [1]PETSC ERROR: MatView_MPIAIJ_Binary() line 1376 in src/mat/impls/aij/mpi/mpiaij.c
> [1]PETSC ERROR: MatView_MPIAIJ_ASCIIorDraworSocket() line 1479 in src/mat/impls/aij/mpi/mpiaij.c
> [1]PETSC ERROR: MatView_MPIAIJ() line 1575 in src/mat/impls/aij/mpi/mpiaij.c
> [1]PETSC ERROR: MatView() line 755 in src/mat/interface/matrix.c
> [1]PETSC ERROR: main() line 93 in test.cpp
> application called MPI_Abort(MPI_COMM_WORLD, 1) - process 1
> APPLICATION TERMINATED WITH THE EXIT STRING: Hangup (signal 1)
> vishy
