[petsc-users] PETSc 3.2 release candidate
Sat Sep 3 13:04:04 CDT 2011
On Sat, Sep 3, 2011 at 6:04 PM, Tabrez Ali <stali at geology.wisc.edu> wrote:
> Hello
> What is the equivalent of $(PETSC_INCLUDE) in petsc-3.2? I am using Fortran
> and my files end in .f90. My working Makefile for petsc-3.1 (with gfortran)
> looks like
> include ${PETSC_DIR}/conf/variables
> include ${PETSC_DIR}/conf/rules
> all:
>        mpif90 -c -Wall -x f95-cpp-input $(PETSC_INCLUDE) a.f90 b.f90 c.f90
>        $(FLINKER) a.o b.o c.o $(PETSC_FORTRAN_LIB) $(PETSC_LIB) -o exec
>        $(RM) *.o *.mod
> With 3.2 I get the error
> stali at i5:~/src$ make all
> mpif90 -c -Wall -x f95-cpp-input a.f90 b.f90 c.f90
> b.f90:8:0: fatal error: finclude/petscsys.h: No such file or directory
In order to get around some portability problems we split PETSC_INCLUDE into
  ${PETSC_CC_INCLUDES}
and
  ${PETSC_FC_INCLUDES}
I believe you want the later.
     Matt
> Thanks in advance
> Tabrez
> On 09/02/2011 09:01 PM, Satish Balay wrote:
>> Also one can use the following tarball. It will correspond to
>> petsc-3.2 sources for the next few days. And i've set it up to be
>> updated every 3 hours [from the sources in mercurial].
>> http://ftp.mcs.anl.gov/pub/**petsc/petsc-dev.tar.gz<http://ftp.mcs.anl.gov/pub/petsc/petsc-dev.tar.gz>
>> Satish
>> On Fri, 2 Sep 2011, Barry Smith wrote:
>>     You can find the PETSc 3.2 release candidate via Mecurial at:
>>>> ssh://petsc@petsc.cs.iit.edu//**hg/petsc/releases/petsc-3.2<http://petsc@petsc.cs.iit.edu//hg/petsc/releases/petsc-3.2>                       or
>>>> http://petsc.cs.iit.edu/petsc/**releases/petsc-3.2<http://petsc.cs.iit.edu/petsc/releases/petsc-3.2>
>>>> ssh://petsc@petsc.cs.iit.edu//**hg/petsc/releases/BuildSystem-**3.2<http://petsc@petsc.cs.iit.edu//hg/petsc/releases/BuildSystem-3.2>          or
>>>> http://petsc.cs.iit.edu/petsc/**releases/BuildSystem-3.2<http://petsc.cs.iit.edu/petsc/releases/BuildSystem-3.2>
>>>    If you find any problems please let us know.  We'll be making the
>>> tarball in a couple of days.
>>>    Thanks
>>>     Barry
>>>    If you fix anything, please make the fix in petsc-3.2 not petsc-dev
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110903/c0313c67/attachment.htm>
