[petsc-users] Matrix is missing diagonal entry
Rongliang Chen
rongliang.chan at gmail.com
Thu Sep 1 11:38:53 CDT 2011
Hi Jed and Andrew,
Thanks for your reply.
It's a little strange that this problem appears for some meshes and number
of processors. When I run the code with 512 processors and the same mesh
there is no such problem. And for some meshes, the code works well with any
number of processors.
Best,
Rongliang
> Message: 3
> Date: Wed, 31 Aug 2011 21:34:00 -0500
> From: Jed Brown <jedbrown at mcs.anl.gov>
> Subject: Re: [petsc-users] Matrix is missing diagonal entry
> To: PETSc users list <petsc-users at mcs.anl.gov>
> Message-ID:
> <CAM9tzSk5+sAGk0fUQy_vB2vfBD_bR4YbRSxR8RZv3Li__YwyTA at mail.gmail.com
> Content-Type: text/plain; charset="utf-8"
> Maybe a mistake implementing boundary conditions?
> Message: 5
> Date: Thu, 1 Sep 2011 08:36:23 -0600 (MDT)
> From: Andrew T Barker <Andrew.Barker at Colorado.EDU>
> To: "PETSc users list" <petsc-users at mcs.anl.gov>
> Message-ID: <20110901083623.AKJ70453 at batman.int.colorado.edu>
> Content-Type: text/plain; charset=us-ascii
> This has happened to me if I forget to call MatAssemblyBegin/End. The
> entry will still print out in the MatView(), but it won't compute.
> Might not be your problem, but worth a shot.
> ---- Original message ----
> >Date: Wed, 31 Aug 2011 18:15:14 -0600
> >From: petsc-users-bounces at mcs.anl.gov (on behalf of Rongliang Chen <
> rongliang.chan at gmail.com>)
> >Subject: [petsc-users] Matrix is missing diagonal entry
> >To: PETSc Users mail list <petsc-users at mcs.anl.gov>
> > Hello,
> > I got the error message "Matrix is missing diagonal
> > entry 23548!" when I tried to run my code. I print
> > out the 23548th row and find that the 23548th
> > element of this row is one and the others are zero.
> > Can anyone tell me what's maybe the problem and how
> > to fix this? Thanks.
> > Best Regards,
> > Rongliang
> > /bin/bash: SHELL: readonly variable
> > /bin/bash: PATH: readonly variable
> > [255]PETSC ERROR: --------------------- Error
> > Message ------------------------------------
> > [255]PETSC ERROR: Object is in wrong state!
> > [255]PETSC ERROR: Matrix is missing diagonal entry
> > 23548!
> > [255]PETSC ERROR:
> > [255]PETSC ERROR: Petsc Release Version 3.1.0, Patch
> > 8, Thu Mar 17 13:37:48 CDT 2011
> > [255]PETSC ERROR: See docs/changes/index.html for
> > recent updates.
> > [255]PETSC ERROR: See docs/faq.html for hints about
> > trouble shooting.
> > [255]PETSC ERROR: See docs/index.html for manual
> > pages.
> > [255]PETSC ERROR:
> > [255]PETSC ERROR:
> > /home/rchen/soft/fixedmesh/Cannula/./joab on a
> > bgl-ibm-g named R02M1N0 by Unknown Wed Aug 31
> > 17:36:32 2011
> > [255]PETSC ERROR: Libraries linked from
> > /home/rchen/soft/petsc-3.1-p8-nodebug/bgl-ibm-goto-O3_440d/lib
> > [255]PETSC ERROR:
> > [255]PETSC ERROR: MatILUFactorSymbolic_SeqAIJ_ilu0()
> > line 1627 in src/mat/impls/aij/seq/aijfact.c
> > [255]PETSC ERROR: MatILUFactorSymbolic_SeqAIJ() line
> > 1731 in src/mat/impls/aij/seq/aijfact.c
> > [255]PETSC ERROR: MatILUFactorSymbolic() line 5464
> > in src/mat/interface/matrix.c
> > [255]PETSC ERROR: PCSetUp_ILU() line 204 in
> > src/ksp/pc/impls/factor/ilu/ilu.c
> > [255]PETSC ERROR: PCSetUp() line 795 in
> > src/ksp/pc/interface/precon.c
> > [255]PETSC ERROR: KSPSetUp() line 237 in
> > src/ksp/ksp/interface/itfunc.c
> > [255]PETSC ERROR: PCSetUpOnBlocks_ASM() line 335 in
> > src/ksp/pc/impls/asm/asm.c
> > [255]PETSC ERROR: PCSetUpOnBlocks() line 828 in
> > [255]PETSC ERROR: KSPSetUpOnBlocks() line 159 in
> > [255]PETSC ERROR: KSPSolve() line 354 in
> > [255]PETSC ERROR: SNES_KSPSolve() line 2944 in
> > src/snes/interface/snes.c
> > [255]PETSC ERROR: SNESSolve() line 2255 in
> > [255]PETSC ERROR: TimeStep() line 1462 in
> > /home/rlchen/rlchen/soft/fixedmesh/code_changed/joab.c
> > [255]PETSC ERROR: SolveSteadyState() line 1362 in
> > [255]PETSC ERROR: ComputefixedBoundary() line 505 in
> > [255]PETSC ERROR: JoabCtxSolve() line 165 in
> > [255]PETSC ERROR: main() line 107 in
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110901/de2b5e5b/attachment.htm>
