[petsc-users] Does an array obtained with VecGetArray remain valid after vec's values changed?
Dominik Szczerba dominik at itis.ethz.ch
Mon Oct 31 16:56:55 CDT 2011
Thanks Jed for the detailed elaboration. No, I am not overloading []
operator, really doing C++ minimalistically actually. My question is
much simpler, just if the pointer obtained with VecGetArray will
continue to reflect the correct values despite the intermittent calls
to VecSetValues and VecAssemblyBegin/End.
Many thanks,
Dominik
On Mon, Oct 31, 2011 at 4:47 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Mon, Oct 31, 2011 at 09:19, Satish Balay <balay at mcs.anl.gov> wrote:
>> Also - after you are done using the array - you should call
>> VecRestoreArray().  And you should be changing the values only between
>> these two calls. [i.e do not stash the pointer for later use - and
>> keep changing values with this pointer - after the call to
>> VecRestroeArray()].  If you need to change the vec again - call
>> VecGetArray() again.
> This seems to come up frequently. People check that the implementation is
> mostly correct when they stash the pointer and then want to do this, perhaps
> because of some false sense that it is an "optimization". Don't do that.
> Changing the values in this way can invalidate norms and artificially
> restricts what can be done with other Vec types or possible future multicore
> memory optimizations. Just call VecGetArray() and VecRestoreArray() around
> any place that you modify values.
> Some people want to wrap PETSc Vecs in their own C++ type that implements
> operator[]. I don't recommend wrapping because it makes implementing
> callbacks from PETSc more complicated. (You get a plain PETSc Vec and have
> to wrap it before you can use it, which means that any extra semantic
> information that you wanted to have in the wrapper needs to be reconstructed
> (where?). You should be able to compose that extra semantic information with
> a PETSc Vec (or DM) so that all the callbacks get that information.) But if
> you insist on wrapping and implementing operator[], you have a few choices:
> 1. Put VecGetArray() in the operator[] implementation, return a proxy object
> with VecRestoreArray() in the proxy's destructor. This is the finest grain
> option and I don't like its semantics. To have multiple proxies live at
> once, you would need to hold a reference count so that VecRestoreArray() is
> only called when the last one goes out of scope. Although unfortunately a
> common idiom in C++, returning proxy objects from operator[] is complicated
> and unavoidably causes lots of painful semantics, see std::vector<bool>.
> 2. Call VecGetArray() when needed in the operator[] implementation and have
> an explicit function in your wrapper that ends the access phase by calling
> VecRestoreArray(). I don't like this because there isn't a good way to
> declare whether you will be modifying the vector or whether access is
> read-only (can use VecGetArrayRead()) and I think some explicit statement
> that you are about to modify a Vec is good documentation.
> 3. Have explicit functions in your wrappers to gain and restore access, with
> operator[] only allowed between these calls. This has the same semantics as
> using the native PETSc API, but it lets you access without needing to
> declare local pointers (you still needed your wrappers).
> 4. Have a function in your wrapper that returns an accessor object that
> implements operator[] (in this model, your wrapper does not implement
> operator[] itself). The accessor's destructor can call VecRestoreArray(). A
> variant of this is to have an accessor whose constructor takes your wrapper
> or a PETSc Vec directly. This is my favorite option if you are trying to
> avoid raw pointers in your internal interfaces.
> PetscErrorCode YourCallback(...,Vec vec) {
> VecAccessor a(vec, access_mode); // Can associate grid information and
> possibly update ghost values.
> for (int i=a.xs; i<a.xs+a.xm; i++) { // Some grid traversal
>  a[i] = ...;
> // Destructor calls VecRestoreArray(). It could also accumulate ghost values
> depending on access_mode.
