[petsc-users] Block ILU with AIJ matrix?
behzad baghapour behzad.baghapour at gmail.com
Mon Oct 31 00:58:05 CDT 2011
I hope so.
On Mon, Oct 31, 2011 at 9:20 AM, Gong Ding <gdiso at ustc.edu> wrote:
> I had also considered use max block size. But it is not efficient here.
> Hope petsc support nonuniform block size one day.
> I think you may choose the maximum block size as a BAIJ dimension. However
> ITSOL has variable BLOCK ILU routine which may help you BUT it is not
> paralleled.
> http://www-users.cs.umn.edu/~saad/software/ITSOL/index.html
> B.B.
Behzad Baghapour
Ph.D. Candidate, Mechecanical Engineering
University of Tehran, Tehran, Iran
https://sites.google.com/site/behzadbaghapour
Fax: 0098-21-88020741
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111031/1b95947c/attachment-0001.htm>
