[petsc-users] multiblock question
Sat Oct 29 21:03:02 CDT 2011
On Sat, Oct 29, 2011 at 6:58 PM, Shao-Ching Huang <huangsc at gmail.com> wrote:
> Hi, I have additional questions:
> 1. Suppose I create DMDA0 on two processes {0,1} (communicator comm0)
> and DMDA1 on another two processes {2,3} (communicator comm1). Can I
> DMCompositeAddDM() them into DMComposite (created using communicator
> MPI_COMM_WORLD, containing all 4 processes, 0-3)?
No. This is due to the complexity of MPI for collectives, etc between
communicators.
Instead, you should use the full communicator for both, but give no
vertices to
ranks you want to leave out. This means you will have to partition the DMDA
yourself,
but this is straightforward. There are no performance hits when
communicating ghost
values, and the reductions inside the solve would need all the procs anyway.
> 2. Suppose DMDA0 and DMDA1 are 2D Cartesian domains, and that the
> right-hand-side of DMDA0 is "connected" to DMDA1 (just like the
> subdomains within a regular DMDA). Which API should I use to tell
> DMComposite that the "right side" (say i=Nx, all j) of DMDA0 is
> connected to the "left side" (say i=0, all j) of DMDA1. I suppose I
> need to use IS index set somewhere.
This is more complicated. All our examples (like SNES ex28) are not grids
or scalar which
are not coupled. You would need to construct the LocalToGlobal mapping for
this collection
of grids (which is a set of two ISes). Here is the current code:
http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/src/dm/impls/composite/pack.c.html#DMCompositeGetISLocalToGlobalMappings
Notice that the mapping for each DMDA is just concatenated. You code would
look similar,
except that you would knit together one edge.
Since we have never had anyone ask for this, the interface is still
primitive. If
you have a suggestion for a nice way to construct this IS, please let us
know.
      Matt
> Thanks,
> Shao-Ching
> On Fri, Oct 28, 2011 at 5:17 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
> > On Fri, Oct 28, 2011 at 11:48 PM, Shao-Ching Huang <huangsc at gmail.com>
> > wrote:
> >> Hi
> >> We are planning a new (finite volume) multiblock code, in which each
> >> block has logically structured mesh. We plan to create one DMDA for
> >> one block (which could span across 1 or more processes; we already
> >> have code). What would be the recommended PETSc-way to couple these
> >> blocks together for implicit solves? We also need ghosted region
> >> between two connected blocks (just like the ghost regions among the
> >> subdomains within a DMDA) for interpolation.
> > I think the idea here is to use a DMComposite to couple together these
> > DMDAs. You
> > would have to specify the coupling explicitly since we have no way of
> > knowing how they
> > are connected, but after that, the GlobalToLocal() should work just the
> > same.
> >   Thanks,
> >      Matt
> >> Thanks.
> >> Shao-Ching
> > What most experimenters take for granted before they begin their
> experiments
> > is infinitely more interesting than any results to which their
> experiments
> > lead.
> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111030/cacfc37d/attachment.htm>
