[petsc-users] petsc-3.1-p8 test error
    Kyunghoon Lee
    aeronova.mailing at gmail.com
    Fri Oct 28 14:50:11 CDT 2011
Thanks, but 3.2 does not work with slepc-3.1. :(
On Fri, Oct 28, 2011 at 9:31 PM, Hong Zhang <hzhang at mcs.anl.gov> wrote:
> petsc-3.1 is more than two years old. The latest release is 3.2.
> These are warnings in fortran. You can ignore.
> Hong
> On Fri, Oct 28, 2011 at 5:46 AM, Kyunghoon Lee
> <aeronova.mailing at gmail.com> wrote:
> > Hi all,
> > I have configured petsc-3.1-p8 with the following options on my Mac OS X
> > 10.6.8 (primarily to support complex variables):
> > ./configure
> > --prefix=/Users/aeronova/Development/local/lib64/petsc/petsc-3.1-p8
> > --download-mpich=1 --download-blacs=1 --download-parmetis=1
> > --download-scalapack=1 --download-mumps=1 --download-umfpack=1
> > --with-scalar-type=complex --with-clanguage=C++
> > At the test stage, I got the following error --- it seems to have
> something
> > to do with FORTRAN, although I do not need FORTRAN support.  I'd
> appreciate
> > if someone could help me with this error.
> > Regards,
> > K. Lee.
> > $ make
> PETSC_DIR=/Users/aeronova/Development/local/lib64/petsc/petsc-3.1-p8
> > test
> > Running test examples to verify correct installation
> > C/C++ example src/snes/examples/tutorials/ex19 run successfully with 1
> MPI
> > process
> > C/C++ example src/snes/examples/tutorials/ex19 run successfully with 2
> MPI
> > processes
> > --------------Error detected during compile or
> link!-----------------------
> > See
> http://www.mcs.anl.gov/petsc/petsc-2/documentation/troubleshooting.html
> > /Users/aeronova/Development/local/lib64/petsc/petsc-3.1-p8/bin/mpif90 -c
> > -Wall -Wno-unused-variable -g
> > -I/Users/aeronova/Development/local/lib64/petsc/petsc-3.1-p8/include
> -o
> > ex5f.o ex5f.F
> > Warning (115): Line 92 of ex5f.F is being truncated
> > Warning (115): Line 113 of ex5f.F is being truncated
> > Warning (115): Line 114 of ex5f.F is being truncated
> > Warning (115): Line 125 of ex5f.F is being truncated
> > Warning (115): Line 126 of ex5f.F is being truncated
> > Warning (115): Line 127 of ex5f.F is being truncated
> > Warning (115): Line 128 of ex5f.F is being truncated
> > Warning (115): Line 130 of ex5f.F is being truncated
> > Warning (115): Line 132 of ex5f.F is being truncated
> > Warning (115): Line 188 of ex5f.F is being truncated
> > Warning (115): Line 344 of ex5f.F is being truncated
> > Warning (115): Line 348 of ex5f.F is being truncated
> > Warning (115): Line 412 of ex5f.F is being truncated
> > Warning (115): Line 417 of ex5f.F is being truncated
> > Warning (115): Line 517 of ex5f.F is being truncated
> > Warning (115): Line 522 of ex5f.F is being truncated
> > Warning (115): Line 528 of ex5f.F is being truncated
> > Warning (115): Line 537 of ex5f.F is being truncated
> > -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress
> > -Wl,-commons,use_dylibs -Wl,-search_paths_first
> > -Wl,-commons,use_dylibs -Wl,-search_paths_first   -Wall
> > -g  -o ex5f ex5f.o
> > -L/Users/aeronova/Development/local/lib64/petsc/petsc-3.1-p8/lib
> > -L/Users/aeronova/Development/local/lib64/petsc/petsc-3.1-p8/lib -lpetsc
> > -L/usr/X11R6/lib -lX11
> > -L/Users/aeronova/Development/local/lib64/petsc/petsc-3.1-p8/lib -lcmumps
> > -ldmumps -lsmumps -lzmumps -lmumps_common -lpord -lscalapack -lblacs
> > -lparmetis -lmetis -lumfpack -lamd -llapack -lblas
> > -L/usr/lib/gcc/i686-apple-darwin10/4.2.1/x86_64
> > -L/usr/lib/i686-apple-darwin10/4.2.1
> > -L/usr/lib/gcc/i686-apple-darwin10/4.2.1 -ldl -lpmpich -lmpich -lSystem
> > -lmpichf90 -lf95 -lm -L/opt/local/lib/g95/x86_64-apple-darwin10/4.2.4
> > -L/usr/lib/gcc -lm -lmpichcxx -lstdc++ -lmpichcxx -lstdc++ -ldl -lpmpich
> > -lmpich -lSystem -ldl
> > /bin/rm -f ex5f.o
> > Fortran example src/snes/examples/tutorials/ex5f run successfully with 1
> MPI
> > process
> > Completed test examples
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111029/266f3b24/attachment.htm>
