[petsc-users] [petsc-maint #94846] Collecting Values in a Parallel Vector
Fri Oct 28 14:37:04 CDT 2011
   You need to run in the debugger, one of your arguments to the function call is not right for some reason.
   Barry
On Oct 28, 2011, at 5:24 AM, PEREZ CERQUERA MANUEL RICARDO wrote:
> Hi everybody,
> I would like to know How do I add values from a sequential
> PETSC vector from each process into a parallel vector? ,
> I'm doing this:
>     PetscScatter ctx
>     PetscInt NOfTotalBEMFunctions
>     idx=(/(i,i=0,NOfTotalBEMFunctions-1)/)
> I create the Vectors LocalZNearNOfNonZeros and
> GlobalZNearNOfNonZeros with VecCreateSeq(...) and
> VecCreateMPI(...) respectively
>     CALL
> ISCreateGeneral(PETSC_COMM_SELF,NOfTotalBEMFunctions,idx,from,ierr);
>     CALL
> ISCreateGeneral(PETSC_COMM_WORLD,NOfTotalBEMFunctions,idx,towards,ierr);
>     CALL
> VecScatterCreate(LocalZNearNOfNonZeros,from,GlobalZNearNOfNonZeros,towards,ctx,ierr);
>     CALL
> VecScatterBegin(ctx,LocalZNearNOfNonZeros,GlobalZNearNOfNonZeros,ADD_VALUES,SCATTER_FORWARD,ierr)
>     CALL
> VecScatterEnd(ctx,LocalZNearNOfNonZeros,GlobalZNearNOfNonZeros,ADD_VALUES,SCATTER_FORWARD,ierr)
>     CALL VecScatterDestroy(ctx,ierr);
> So when I run in two Process , It crashes in
> ISCreateGeneral and I got this error:
> [1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
> Violation, probably m
> emory access out of range
> [1]PETSC ERROR: Try option -start_in_debugger or
> -on_error_attach_debugger
> [1]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.h
> tml#valgrind[1]PETSC ERROR: or try http://valgrind.org on
> GNU/linux and Apple Ma
> c OS X to find memory corruption errors
> [1]PETSC ERROR: likely location of problem given in stack
> below
> [1]PETSC ERROR: ---------------------  Stack Frames
> [0]PETSC ERROR:
> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
> [0]PETSC ERROR: Try option -start_in_debugger or
> [0]PETSC ERROR: or see
> tml#valgrind[0]PETSC ERROR: or try http://valgrind.org on
> [0]PETSC ERROR: likely location of problem given in stack
> below
> [0]PETSC ERROR: ---------------------  Stack Frames
> [1]PETSC ERROR: Note: The EXACT line numbers in the stack
> are not available,
> [1]PETSC ERROR:       INSTEAD the line number of the start
> of the function
> [1]PETSC ERROR:       is given.
> [0]PETSC ERROR: Note: The EXACT line numbers in the stack
> are not available,
> [0]PETSC ERROR:       INSTEAD the line number of the start
> of the function
> [0]PETSC ERROR:       is given.
> [1]PETSC ERROR: --------------------- Error Message
> [1]PETSC ERROR: Signal received!
> [1]PETSC ERROR:
> [1]PETSC ERROR: Petsc Release Version 3.2.0, Patch 2, Fri
> Sep 16 10:10:45 CDT 20
> 11
> [1]PETSC ERROR: See docs/changes/index.html for recent
> updates.
> [1]PETSC ERROR: See docs/faq.html for hints about trouble
> shooting.
> [1]PETSC ERROR: See docs/index.html for manual pages.
> [1]PETSC ERROR:
> [1]PETSC ERROR: C:\Documents and
> Settings\d022117\Desktop\MPIRunsPatrju\PAtreju.
> exe on a arch-mswi named GVSRV by d022117 Fri Oct 28
> 12:18:28 2011
> [1]PETSC ERROR: Libraries linked from
> /home/d022117/petsc-3.2-p2/arch-mswin-cxx-
> debug/lib
> [1]PETSC ERROR: Configure run at Fri Sep 30 18:13:15 2011
> [1]PETSC ERROR: Configure options --with-cc="win32fe cl"
> --with-fc="win32fe ifor
> t" --with-cxx="win32fe cl" --download-f-blas-lapack=1
> --with-scalar-type=complex
>  --with-clanguage=cxx --useThreads=0
> [1]PETSC ERROR:
> [1]PETSC ERROR: User provided function() line 0 in unknown
> directory unknown fil
> e
> application called MPI_Abort(MPI_COMM_WORLD, 59) - process
> 1
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Signal received!
> [0]PETSC ERROR:
> [0]PETSC ERROR: Petsc Release Version 3.2.0, Patch 2, Fri
> 11
> [0]PETSC ERROR: See docs/changes/index.html for recent
> updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble
> shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR:
> [0]PETSC ERROR: C:\Documents and
> 12:18:28 2011
> [0]PETSC ERROR: Libraries linked from
> debug/lib
> [0]PETSC ERROR: Configure run at Fri Sep 30 18:13:15 2011
> [0]PETSC ERROR: Configure options --with-cc="win32fe cl"
> [0]PETSC ERROR:
> [0]PETSC ERROR: User provided function() line 0 in unknown
> e
> 0
> job aborted:
> rank: node: exit code[: error message]
> 0: gvsrv.delen.polito.it: 59: process 0 exited without
> calling finalize
> 1: gvsrv.delen.polito.it: 59: process 1 exited without
> calling finalize
> I don't know how to solve it, and I would like to know if
> I'm really doing well the gatter operation.
> Thanks, Manuel .
> Eng. Manuel Ricardo Perez Cerquera. MSc. Ph.D student
> Antenna and EMC Lab (LACE)
> Istituto Superiore Mario Boella (ISMB)
> Politecnico di Torino
> Via Pier Carlo Boggio 61, Torino 10138, Italy
> Email: manuel.perezcerquera at polito.it
> Phone: +39 0112276704
> Fax: +39 011 2276 299
