[petsc-users] Collecting Values in a Parallel Vector
Dominik Szczerba dominik at itis.ethz.ch
Fri Oct 28 09:38:44 CDT 2011
Run in debugger, you will catch the error instantly.
On Fri, Oct 28, 2011 at 12:24 PM, PEREZ CERQUERA MANUEL RICARDO
<manuel.perezcerquera at polito.it> wrote:
> Hi everybody,
> I would like to know How do I add values from a sequential PETSC vector from
> each process into a parallel vector? , I'm doing this:
>    PetscScatter ctx
>    PetscInt NOfTotalBEMFunctions
>    idx=(/(i,i=0,NOfTotalBEMFunctions-1)/)
> I create the Vectors LocalZNearNOfNonZeros and GlobalZNearNOfNonZeros with
> VecCreateSeq(...) and VecCreateMPI(...) respectively
>    CALL ISCreateGeneral(PETSC_COMM_SELF,NOfTotalBEMFunctions,idx,from,ierr);
>    CALL
> ISCreateGeneral(PETSC_COMM_WORLD,NOfTotalBEMFunctions,idx,towards,ierr);
>    CALL
> VecScatterCreate(LocalZNearNOfNonZeros,from,GlobalZNearNOfNonZeros,towards,ctx,ierr);
>    CALL
> VecScatterBegin(ctx,LocalZNearNOfNonZeros,GlobalZNearNOfNonZeros,ADD_VALUES,SCATTER_FORWARD,ierr)
>    CALL
> VecScatterEnd(ctx,LocalZNearNOfNonZeros,GlobalZNearNOfNonZeros,ADD_VALUES,SCATTER_FORWARD,ierr)
>    CALL VecScatterDestroy(ctx,ierr);
> So when I run in two Process , It crashes in ISCreateGeneral and I got this
> error:
> [1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably m
> emory access out of range
> [1]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [1]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.h
> tml#valgrind[1]PETSC ERROR: or try http://valgrind.org on GNU/linux and
> Apple Ma
> c OS X to find memory corruption errors
> [1]PETSC ERROR: likely location of problem given in stack below
> [1]PETSC ERROR: ---------------------  Stack Frames
> [0]PETSC ERROR:
> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably m
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see
> tml#valgrind[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and
> Apple Ma
> [0]PETSC ERROR: likely location of problem given in stack below
> [0]PETSC ERROR: ---------------------  Stack Frames
> [1]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
> [1]PETSC ERROR:       INSTEAD the line number of the start of the function
> [1]PETSC ERROR:       is given.
> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
> [0]PETSC ERROR:       INSTEAD the line number of the start of the function
> [0]PETSC ERROR:       is given.
> [1]PETSC ERROR: --------------------- Error Message
> [1]PETSC ERROR: Signal received!
> [1]PETSC ERROR:
> [1]PETSC ERROR: Petsc Release Version 3.2.0, Patch 2, Fri Sep 16 10:10:45
> CDT 20
> 11
> [1]PETSC ERROR: See docs/changes/index.html for recent updates.
> [1]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [1]PETSC ERROR: See docs/index.html for manual pages.
> [1]PETSC ERROR:
> [1]PETSC ERROR: C:\Documents and
> Settings\d022117\Desktop\MPIRunsPatrju\PAtreju.
> exe on a arch-mswi named GVSRV by d022117 Fri Oct 28 12:18:28 2011
> [1]PETSC ERROR: Libraries linked from
> /home/d022117/petsc-3.2-p2/arch-mswin-cxx-
> debug/lib
> [1]PETSC ERROR: Configure run at Fri Sep 30 18:13:15 2011
> [1]PETSC ERROR: Configure options --with-cc="win32fe cl" --with-fc="win32fe
> ifor
> t" --with-cxx="win32fe cl" --download-f-blas-lapack=1
> --with-scalar-type=complex
>  --with-clanguage=cxx --useThreads=0
> [1]PETSC ERROR:
> [1]PETSC ERROR: User provided function() line 0 in unknown directory unknown
> fil
> e
> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 1
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Signal received!
> [0]PETSC ERROR:
> [0]PETSC ERROR: Petsc Release Version 3.2.0, Patch 2, Fri Sep 16 10:10:45
> CDT 20
> 11
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR:
> [0]PETSC ERROR: C:\Documents and
> [0]PETSC ERROR: Libraries linked from
> debug/lib
> [0]PETSC ERROR: Configure run at Fri Sep 30 18:13:15 2011
> [0]PETSC ERROR: Configure options --with-cc="win32fe cl" --with-fc="win32fe
> ifor
> [0]PETSC ERROR:
> [0]PETSC ERROR: User provided function() line 0 in unknown directory unknown
> fil
> e
> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
> job aborted:
> rank: node: exit code[: error message]
> 0: gvsrv.delen.polito.it: 59: process 0 exited without calling finalize
> 1: gvsrv.delen.polito.it: 59: process 1 exited without calling finalize
> I don't know how to solve it, and I would like to know if I'm really doing
> well the gatter operation.
> Thanks, Manuel .
> Eng. Manuel Ricardo Perez Cerquera. MSc. Ph.D student
> Antenna and EMC Lab (LACE)
> Istituto Superiore Mario Boella (ISMB)
> Politecnico di Torino
> Via Pier Carlo Boggio 61, Torino 10138, Italy
> Email: manuel.perezcerquera at polito.it
> Phone: +39 0112276704
> Fax: +39 011 2276 299
