[petsc-users] Collecting Values in a Parallel Vector
PEREZ CERQUERA MANUEL RICARDO manuel.perezcerquera at polito.it
Fri Oct 28 05:24:11 CDT 2011
Hi everybody,
I would like to know How do I add values from a sequential
PETSC vector from each process into a parallel vector? ,
I'm doing this:
     PetscScatter ctx
     PetscInt NOfTotalBEMFunctions
     idx=(/(i,i=0,NOfTotalBEMFunctions-1)/)
I create the Vectors LocalZNearNOfNonZeros and
GlobalZNearNOfNonZeros with VecCreateSeq(...) and
VecCreateMPI(...) respectively
     CALL
ISCreateGeneral(PETSC_COMM_SELF,NOfTotalBEMFunctions,idx,from,ierr);
     CALL
ISCreateGeneral(PETSC_COMM_WORLD,NOfTotalBEMFunctions,idx,towards,ierr);
     CALL
VecScatterCreate(LocalZNearNOfNonZeros,from,GlobalZNearNOfNonZeros,towards,ctx,ierr);
     CALL
VecScatterBegin(ctx,LocalZNearNOfNonZeros,GlobalZNearNOfNonZeros,ADD_VALUES,SCATTER_FORWARD,ierr)
     CALL
VecScatterEnd(ctx,LocalZNearNOfNonZeros,GlobalZNearNOfNonZeros,ADD_VALUES,SCATTER_FORWARD,ierr)
     CALL VecScatterDestroy(ctx,ierr);
So when I run in two Process , It crashes in
ISCreateGeneral and I got this error:
[1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
Violation, probably m
emory access out of range
[1]PETSC ERROR: Try option -start_in_debugger or
-on_error_attach_debugger
[1]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.h
tml#valgrind[1]PETSC ERROR: or try http://valgrind.org on
GNU/linux and Apple Ma
c OS X to find memory corruption errors
[1]PETSC ERROR: likely location of problem given in stack
below
[1]PETSC ERROR: ---------------------  Stack Frames
[0]PETSC ERROR:
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
[0]PETSC ERROR: Try option -start_in_debugger or
[0]PETSC ERROR: or see
tml#valgrind[0]PETSC ERROR: or try http://valgrind.org on
[0]PETSC ERROR: likely location of problem given in stack
below
[0]PETSC ERROR: ---------------------  Stack Frames
[1]PETSC ERROR: Note: The EXACT line numbers in the stack
are not available,
[1]PETSC ERROR:       INSTEAD the line number of the start
of the function
[1]PETSC ERROR:       is given.
[0]PETSC ERROR: Note: The EXACT line numbers in the stack
are not available,
[0]PETSC ERROR:       INSTEAD the line number of the start
of the function
[0]PETSC ERROR:       is given.
[1]PETSC ERROR: --------------------- Error Message
[1]PETSC ERROR: Signal received!
[1]PETSC ERROR:
[1]PETSC ERROR: Petsc Release Version 3.2.0, Patch 2, Fri
Sep 16 10:10:45 CDT 20
11
[1]PETSC ERROR: See docs/changes/index.html for recent
updates.
[1]PETSC ERROR: See docs/faq.html for hints about trouble
shooting.
[1]PETSC ERROR: See docs/index.html for manual pages.
[1]PETSC ERROR:
[1]PETSC ERROR: C:\Documents and
Settings\d022117\Desktop\MPIRunsPatrju\PAtreju.
exe on a arch-mswi named GVSRV by d022117 Fri Oct 28
12:18:28 2011
[1]PETSC ERROR: Libraries linked from
/home/d022117/petsc-3.2-p2/arch-mswin-cxx-
debug/lib
[1]PETSC ERROR: Configure run at Fri Sep 30 18:13:15 2011
[1]PETSC ERROR: Configure options --with-cc="win32fe cl"
--with-fc="win32fe ifor
t" --with-cxx="win32fe cl" --download-f-blas-lapack=1
--with-scalar-type=complex
  --with-clanguage=cxx --useThreads=0
[1]PETSC ERROR:
[1]PETSC ERROR: User provided function() line 0 in unknown
directory unknown fil
e
application called MPI_Abort(MPI_COMM_WORLD, 59) - process
1
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Signal received!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Release Version 3.2.0, Patch 2, Fri
11
[0]PETSC ERROR: See docs/changes/index.html for recent
updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble
shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: C:\Documents and
12:18:28 2011
[0]PETSC ERROR: Libraries linked from
debug/lib
[0]PETSC ERROR: Configure run at Fri Sep 30 18:13:15 2011
[0]PETSC ERROR: Configure options --with-cc="win32fe cl"
[0]PETSC ERROR:
[0]PETSC ERROR: User provided function() line 0 in unknown
e
0
job aborted:
rank: node: exit code[: error message]
0: gvsrv.delen.polito.it: 59: process 0 exited without
calling finalize
1: gvsrv.delen.polito.it: 59: process 1 exited without
calling finalize
I don't know how to solve it, and I would like to know if
I'm really doing well the gatter operation.
Thanks, Manuel .
Eng. Manuel Ricardo Perez Cerquera. MSc. Ph.D student
Antenna and EMC Lab (LACE)
Istituto Superiore Mario Boella (ISMB)
Politecnico di Torino
Via Pier Carlo Boggio 61, Torino 10138, Italy
Email: manuel.perezcerquera at polito.it
Phone: +39 0112276704
Fax: +39 011 2276 299
