[petsc-users] Petsc-3.2 with superlu_dist building error
Xiaoye S. Li xsli at lbl.gov
Thu Oct 27 16:28:47 CDT 2011
Okay, the older superlu_4.2.tar.gz is reverted, and the new one is
superlu_4.3.tar.gz.
Sherry
On Thu, Oct 27, 2011 at 12:20 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Thu, Oct 27, 2011 at 13:11, Xiaoye S. Li <xsli at lbl.gov> wrote:
>> The error is related to the new SuperLU_DIST (v3.0), not serial SuperLU.
>> In PETSc / SuperLU_DIST wrapper:  superlu_dist.c, line 634,  DOUBLE
>> should be replaced by SLU_DOUBLE.
> Sherry, this is in the released version of PETSc which uses SuperLU_DIST-2.5
> and SuperLU-4.2. While petsc-dev has been updated for SuperLU_DIST-3.0, your
> API change in the SuperLU-4.2 tarball breaks petsc-3.2 (and any other
> library that was released with support for SuperLU-4.2). As we discussed
> last week, please revert the SuperLU-4.2 tarball to have the same API as it
> had when it was released and make the API change in a new tarball (e.g.
> 4.3).
