[petsc-users] Petsc-3.2 with superlu_dist building error
Jed Brown
jedbrown at mcs.anl.gov
Thu Oct 27 13:44:45 CDT 2011
On Thu, Oct 27, 2011 at 12:34, Ping Rong <ping.rong at tuhh.de> wrote:
> Hello all,
> I was trying to compile the PETSc-3.2-p4 with superlu_dist. The machine is
> running with Ubuntu 10.04, gcc 4.4.5 and cmake 2.8.5. the configuration
> looks like the following:
> ./config/configure.py \
> --with-precision=double \
> --with-blas-lib=$LIBS_DIR/**lapack/lib/libblas.so \
> --with-lapack-lib=$LIBS_DIR/**lapack/lib/liblapack.so \
> --with-scalar-type=complex \
> --with-clanguage=c++ \
> --with-mpi-dir=$LIBS_DIR/**mpich2 \
> --download-superlu=yes \
> --with-superlu=1 \
> --download-parmetis=yes \
> --with-parmetis=1 \
> --download-superlu_dist=yes \
> --with-superlu_dist=1 \
> --with-debugging=no \
> --with-shared-libraries=1
> when I try to run "make all", it throws the error
> [ 60%] Building CXX object CMakeFiles/petsc.dir/src/mat/**
> order/amd/amd.c.o
> /home/xxx/libs/petsc/src/mat/**impls/aij/mpi/superlu_dist/**superlu_dist.c:
> In function ‘PetscErrorCode MatGetFactor_aij_superlu_dist(**_p_Mat*,
> MatFactorType, _p_Mat**)’:
> /home/xxx/libs/petsc/src/mat/**impls/aij/mpi/superlu_dist/**superlu_dist.c:634:
> error: ‘DOUBLE’ was not declared in this scope
> In function ‘PetscErrorCode MatFactorInfo_SuperLU_DIST(_p_**Mat*,
> _p_PetscViewer*)’:
> /home/xxx/libs/petsc/src/mat/**impls/aij/mpi/superlu_dist/**superlu_dist.c:698:
The SuperLU maintainer made an API-incompatible change to the released
tarball.
Sherry, we talked about this last week and I thought you were going to make
a SuperLU-4.3 release with the namespaced enum values?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111027/b3e10550/attachment.htm>
