[petsc-users] Change SNES/TS setting from inside context
behzad baghapour behzad.baghapour at gmail.com
Thu Oct 27 09:28:33 CDT 2011
Actually I want to update the domain according to the global CFL number;
e.g. dt = CFL * dx / Lambda; separately for each cell
( dx is the dimension of the cell and Lambda is the local maximum eigenvalue
of the field )
So, here shift is the maximum time step and I should adjust other cells to
this maximum value?
On Thu, Oct 27, 2011 at 5:49 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Thu, Oct 27, 2011 at 06:44, behzad baghapour <
> behzad.baghapour at gmail.com> wrote:
>> 2- page 120 of PETSc manual (TS): "For location-dependent
>> pseudo-timestepping, the interface function has not yet been created."
>> Is there any way to control time-step locally? (This is due to variable
>> time updating usually needed in PDE solution)
> The documentation needs to be updated. Use TSSetIJacobian() and regard the
> "shift" as a maximum shift (corresponds to minimum time step). If you have a
> cell in which you want to take a 10x longer time step, then use shift/10 in
> that cell. Note that you can use steady-state constraints on some fields.
> For example, src/ts/examples/tutorials/ex26.c (in petsc-dev) uses no shift
> for the velocity components (enforces incompressibility in
> velocity-vorticity form).
Behzad Baghapour
Ph.D. Candidate, Mechecanical Engineering
University of Tehran, Tehran, Iran
https://sites.google.com/site/behzadbaghapour
Fax: 0098-21-88020741
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111027/807b3418/attachment.htm>
