[petsc-users] slepc compilation problem: 'module' object has no attribute 'INSTALL_DIR'
Kyunghoon Lee aeronova.mailing at gmail.com
Thu Oct 27 09:20:48 CDT 2011
Jose,
Thanks for the info.  I guess I have to revert to petsc-3.1.
K. Lee.
On Thu, Oct 27, 2011 at 9:53 PM, Jose E. Roman <jroman at dsic.upv.es> wrote:
> El 27/10/2011, a las 15:51, Kyunghoon Lee escribió:
> > Hi,
> > slpec used to work, but somehow I cannot compile it again after I
> recompiled petsc to enable complex variable support.  Here's what I did:
> > $ export SLEPC_DIR=$PWD
> > $ export
> PETSC_DIR=/Users/aeronova/Development/local/lib64/petsc/petsc-3.2-p4
> > $ export CXX="/usr/bin/mpicxx"
> > $ export CC="/usr/bin/mpicc"
> > $ ./configure
> --prefix=/Users/aeronova/Development/local/lib64/slepc/slepc-3.1-p6
> > Checking environment...
> > Traceback (most recent call last):
> >   File "./configure", line 223, in <module>
> >     log.Write('PETSc install directory: ' + petscconf.INSTALL_DIR)
> > AttributeError: 'module' object has no attribute 'INSTALL_DIR'
> > Plz help me with this error.
> slepc-3.1 is not compatible with petsc-3.2.
> You have to wait for slepc-3.2, which will be out very soon (maybe today).
> Jose
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111027/4d726042/attachment.htm>
