[petsc-users] Change SNES/TS setting from inside context
behzad baghapour
behzad.baghapour at gmail.com
Thu Oct 27 09:18:15 CDT 2011
So, I should define a monitor context "mon" and a function like "Monitor"
which I want to change whatever I wand during each SNES iteration then pass
it to the function
SNESMonitorSet<http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/SNES/SNESMonitorSet.html#SNESMonitorSet>(
snes, Monitor, &mon, 0 );
So is it correct?
On Thu, Oct 27, 2011 at 5:16 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Oct 27, 2011 at 12:44 PM, behzad baghapour <
> behzad.baghapour at gmail.com> wrote:
>> Dear All,
>> 1- Is there any way to change the setting of SNES within its iteration
>> process? ( for example, changing PC type or fill level due to some reasons )
> Yes,
> SNESGetKSP()
> KSPGetPC()
> PC***()
> I would probably put this code in a SNES monitor.
> Matt
> 2- page 120 of PETSc manual (TS): "For location-dependent
>> pseudo-timestepping, the interface function has not yet been created."
>> Is there any way to control time-step locally? (This is due to variable
>> time updating usually needed in PDE solution)
>> Thanks a lot,
>> B. B.
>> Behzad Baghapour
>> Ph.D. Candidate, Mechecanical Engineering
>> University of Tehran, Tehran, Iran
>> https://sites.google.com/site/behzadbaghapour
>> Fax: 0098-21-88020741
> experiments lead.
> -- Norbert Wiener
Behzad Baghapour
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111027/4d01233f/attachment.htm>
