[petsc-users] Log_summary
Rongliang Chen rongliang.chan at gmail.com
Fri Oct 21 17:09:15 CDT 2011
Hello All,
I got a strange thing in my log_summary output (see below). In the output
file, the time spend on the function "MatLUFactorNum" is "1.6966e+02" but
the percent time in this phase (T%) for this function is 20%, which means
that the total time should be 8.483e+02. But the exact total time is
5.506e+02. So what kind of bug can cause this problem? Thanks,
Best,
Rongliang
                         Max       Max/Min        Avg      Total
Time (sec):           5.506e+02      1.00014   5.506e+02
Event                             Count          Time (sec)
Flops                             --- Global ---  --- Stage ---   Total
                                  Max Ratio  Max           Ratio
Max        Ratio   Mess    Avg len  Reduct  %T %F %M %L %R  %T %F %M %L %R
Mflop/s
MatLUFactorNum        20    1.0     1.6966e+02 2.4     1.94e+11 3.2
0.0e+00 0.0e+00 0.0e+00 20  62   0     0    0     20   62  0     0    0
19505
***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r
-fCourier9' to print this document            ***
---------------------------------------------- PETSc Performance Summary:
./joab on a Janus-nod named node1755 with 32 processors, by ronglian Sun Oct
16 16:34:25 2011
Using Petsc Release Version 3.2.0, Patch 1, Mon Sep 12 16:01:51 CDT 2011
Objects:              9.800e+02      1.00000   9.800e+02
Flops:                2.639e+11      2.37776   1.673e+11  5.353e+12
Flops/sec:            4.794e+08      2.37786   3.038e+08  9.722e+09
MPI Messages:         1.057e+05      5.06348   3.760e+04  1.203e+06
MPI Message Lengths:  1.191e+09      2.60674   2.113e+04  2.543e+10
MPI Reductions:       6.213e+03      1.00000
Flop counting convention: 1 flop = 1 real number operation of type
(multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N -->
2N flops
                            and VecAXPY() for complex vectors of length N
--> 8N flops
Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---
-- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts
%Total     Avg         %Total   counts   %Total
 0:      Main Stage: 5.5061e+02 100.0%  5.3531e+12 100.0%  1.203e+06 100.0%
2.113e+04      100.0%  6.212e+03 100.0%
See the 'Profiling' chapter of the users' manual for details on interpreting
output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flops: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and
PetscLogStagePop().
      %T - percent time in this phase         %F - percent flops in this
phase
      %M - percent messages in this phase     %L - percent message lengths
in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over
all processors)
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len
Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
MatMult             2589 1.0 5.0895e+01 7.9 4.45e+09 1.1 4.1e+05 2.2e+03
0.0e+00  5  3 34  4  0   5  3 34  4  0  2655
MatMultTranspose       5 1.0 1.5848e-02 1.3 6.15e+06 1.1 6.6e+02 1.5e+03
0.0e+00  0  0  0  0  0   0  0  0  0  0 11882
MatSolve            2562 1.0 1.1045e+02 1.6 6.03e+10 1.7 0.0e+00 0.0e+00
0.0e+00 17 29  0  0  0  17 29  0  0  0 14238
MatLUFactorSym         4 1.0 2.0894e+00 1.9 0.00e+00 0.0 0.0e+00 0.0e+00
1.2e+01  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum        20 1.0 1.6966e+02 2.4 1.94e+11 3.2 0.0e+00 0.0e+00
0.0e+00 20 62  0  0  0  20 62  0  0  0 19505
MatILUFactorSym        1 1.0 4.8680e-03 1.7 0.00e+00 0.0 0.0e+00 0.0e+00
1.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyBegin     110 1.0 1.6247e+0119.7 0.00e+00 0.0 1.7e+04 6.7e+04
1.8e+02  2  0  1  5  3   2  0  1  5  3     0
MatAssemblyEnd       110 1.0 1.5937e+02 1.0 0.00e+00 0.0 3.0e+03 5.3e+02
1.7e+02 29  0  0  0  3  29  0  0  0  3     0
MatGetRowIJ            5 1.0 3.0132e-02 1.5 0.00e+00 0.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrice      20 1.0 2.9429e+00 1.4 0.00e+00 0.0 1.8e+04 3.9e+05
8.0e+01  0  0  1 27  1   0  0  1 27  1     0
MatGetOrdering         5 1.0 8.6869e-01 1.6 0.00e+00 0.0 0.0e+00 0.0e+00
1.4e+01  0  0  0  0  0   0  0  0  0  0     0
MatIncreaseOvrlp       1 1.0 3.3869e-02 1.0 0.00e+00 0.0 1.6e+03 1.3e+03
8.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatPartitioning        1 1.0 1.1711e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
MatZeroEntries        45 1.0 9.1191e-01 1.3 0.00e+00 0.0 0.0e+00 0.0e+00
VecDot                19 1.0 2.4045e-0213.2 6.91e+05 1.1 0.0e+00 0.0e+00
1.9e+01  0  0  0  0  0   0  0  0  0  0   879
VecMDot             2518 1.0 1.7926e+01 2.5 5.33e+09 1.1 0.0e+00 0.0e+00
2.5e+03  2  3  0  0 41   2  3  0  0 41  9107
VecNorm             2601 1.0 3.0213e+00 5.2 1.23e+08 1.1 0.0e+00 0.0e+00
2.6e+03  0  0  0  0 42   0  0  0  0 42  1243
VecScale            2562 1.0 5.3008e-02 1.4 6.06e+07 1.1 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0 35014
VecCopy              166 1.0 1.3387e-02 1.9 0.00e+00 0.0 0.0e+00 0.0e+00
VecSet              5223 1.0 4.8880e-01 2.2 0.00e+00 0.0 0.0e+00 0.0e+00
VecAXPY              142 1.0 1.1994e-02 1.7 6.89e+06 1.1 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0 17581
VecWAXPY              20 1.0 2.2526e-03 1.6 3.50e+05 1.1 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0  4755
VecMAXPY            2562 1.0 7.9590e+00 1.4 5.45e+09 1.1 0.0e+00 0.0e+00
0.0e+00  1  3  0  0  0   1  3  0  0  0 20969
VecAssemblyBegin      70 1.0 1.4910e-01 4.0 0.00e+00 0.0 5.0e+03 5.6e+02
2.1e+02  0  0  0  0  3   0  0  0  0  3     0
VecAssemblyEnd        70 1.0 2.8467e-04 3.3 0.00e+00 0.0 0.0e+00 0.0e+00
VecScatterBegin     7779 1.0 1.1640e+00 1.6 0.00e+00 0.0 1.2e+06 1.5e+04
0.0e+00  0  0 96 68  0   0  0 96 68  0     0
VecScatterEnd       7779 1.0 1.4521e+0235.3 0.00e+00 0.0 0.0e+00 0.0e+00
0.0e+00 14  0  0  0  0  14  0  0  0  0     0
VecReduceArith         8 1.0 8.0991e-04 1.1 3.05e+05 1.1 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0 11525
VecReduceComm          4 1.0 3.4404e-04 5.1 0.00e+00 0.0 0.0e+00 0.0e+00
4.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize        2562 1.0 2.9302e+00 4.9 1.81e+08 1.1 0.0e+00 0.0e+00
2.5e+03  0  0  0  0 41   0  0  0  0 41  1893
SNESSolve              4 1.0 5.3863e+02 1.0 2.61e+11 2.4 9.9e+05 2.5e+04
4.3e+03 98 98 82 96 69  98 98 82 96 69  9778
SNESLineSearch        19 1.0 8.7346e+00 1.0 6.45e+07 1.1 1.9e+04 1.9e+04
3.5e+02  2  0  2  1  6   2  0  2  1  6   225
SNESFunctionEval      24 1.0 6.6409e+01 1.0 3.06e+07 1.1 2.0e+04 2.1e+04
3.6e+02 12  0  2  2  6  12  0  2  2  6    14
SNESJacobianEval      19 1.0 1.6340e+02 1.0 0.00e+00 0.0 1.1e+04 6.9e+04
1.5e+02 30  0  1  3  2  30  0  1  3  2     0
KSPGMRESOrthog      2518 1.0 2.5557e+01 1.7 1.07e+10 1.1 0.0e+00 0.0e+00
2.5e+03  3  6  0  0 41   3  6  0  0 41 12776
KSPSetup              40 1.0 2.5885e-02 1.4 0.00e+00 0.0 0.0e+00 0.0e+00
KSPSolve              20 1.0 3.1525e+02 1.0 2.64e+11 2.4 1.2e+06 2.1e+04
5.2e+03 57100 96 95 84  57100 96 95 84 16973
PCSetUp               40 1.0 1.7504e+02 2.4 1.94e+11 3.2 2.1e+04 3.3e+05
1.6e+02 21 62  2 27  3  21 62  2 27  3 18906
PCSetUpOnBlocks       20 1.0 1.7249e+02 2.4 1.94e+11 3.2 0.0e+00 0.0e+00
2.7e+01 21 62  0  0  0  21 62  0  0  0 19186
PCApply             2562 1.0 2.0489e+02 2.0 6.03e+10 1.7 7.4e+05 2.2e+04
0.0e+00 28 29 62 65  0  28 29 62 65  0  7675
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
              Matrix    44             34   2570073620     0
 Matrix Partitioning     1              1          640     0
           Index Set   189            182      3025696     0
   IS L to G Mapping     2              1       283604     0
              Vector   688            452    114894176     0
      Vector Scatter    29             25        26300     0
   Application Order     2              2      9335968     0
                SNES     4              2         2544     0
       Krylov Solver    10              6     11645040     0
      Preconditioner    10              6         5456     0
              Viewer     1              0            0     0
Average time to get PetscTime(): 1.19209e-07
Average time for MPI_Barrier(): 1.02043e-05
Average time for zero size MPI_Send(): 2.90573e-06
#PETSc Option Table entries:
-coarse_ksp_rtol 1.0e-1
-coarsegrid
/scratch/stmp00/ronglian/input/Cannula/Cannula_Nest2_E2000_N8241_D70170.fsi
-computeinitialguess
-f
/scratch/stmp00/ronglian/input/Cannula/Cannula_Nest2_E32000_N128961_D1096650.fsi
-geometric_asm
-geometric_asm_overlap 8
-inletu 5.0
-ksp_atol 1e-8
-ksp_gmres_restart 600
-ksp_max_it 3000
-ksp_pc_side right
-ksp_rtol 1.e-2
-ksp_type gmres
-log_summary
-mat_partitioning_type parmetis
-nest_geometric_asm_overlap 4
-nest_ksp_atol 1e-8
-nest_ksp_gmres_restart 800
-nest_ksp_max_it 1000
-nest_ksp_pc_side right
-nest_ksp_rtol 1.e-2
-nest_ksp_type gmres
-nest_pc_asm_type basic
-nest_pc_type asm
-nest_snes_atol 1.e-10
-nest_snes_max_it 20
-nest_snes_rtol 1.e-4
-nest_sub_pc_factor_mat_ordering_type qmd
-nest_sub_pc_factor_shift_amount 1e-8
-sub_pc_factor_shift_type nonzero
-sub_pc_type lu
-viscosity 0.01
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
sizeof(PetscScalar) 8
Configure run at: Tue Sep 13 13:28:48 2011
Configure options: --known-level1-dcache-size=32768
--known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0
--known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=8
--known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=8
--known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8
--known-sizeof-size_t=8 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=8
--known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --with-batch=1
--with-mpi-shared-libraries=1 --known-mpi-shared-libraries=0
--download-f-blas-lapack=1 --download-hypre=1 --download-superlu=1
--download-parmetis=1 --download-superlu_dist=1 --download-blacs=1
--download-scalapack=1 --download-mumps=1 --with-debugging=0
Libraries compiled on Tue Sep 13 13:28:48 2011 on node1367
Machine characteristics:
Linux-2.6.18-238.12.1.el5-x86_64-with-redhat-5.6-Tikanga
Using PETSc directory: /home/ronglian/soft/petsc-3.2-p1
Using PETSc arch: Janus-nodebug
Using C compiler: mpicc  -Wall -Wwrite-strings -Wno-strict-aliasing
-Wno-unknown-pragmas -O  ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: mpif90  -Wall -Wno-unused-variable -O   ${FOPTFLAGS}
${FFLAGS}
Using include paths:
-I/home/ronglian/soft/petsc-3.2-p1/Janus-nodebug/include
-I/home/ronglian/soft/petsc-3.2-p1/include
-I/curc/tools/free/redhat_5_x86_64/openmpi-1.4.3_ib/include
Using C linker: mpicc
Using Fortran linker: mpif90
Using libraries:
-Wl,-rpath,/home/ronglian/soft/petsc-3.2-p1/Janus-nodebug/lib
-L/home/ronglian/soft/petsc-3.2-p1/Janus-nodebug/lib -lpetsc -lX11
-L/home/ronglian/soft/petsc-3.2-p1/Janus-nodebug/lib -lsuperlu_dist_2.5
-lcmumps -ldmumps -lsmumps -lzmumps -lmumps_common -lpord -lparmetis -lmetis
-lHYPRE -lmpi_cxx -lstdc++ -lscalapack -lblacs -lsuperlu_4.2 -lflapack
-lfblas -L/curc/tools/free/redhat_5_x86_64/openmpi-1.4.3_ib/lib
-L/usr/lib/gcc/x86_64-redhat-linux/4.1.2 -ldl -lmpi -lopen-rte -lopen-pal
-lnsl -lutil -lgcc_s -lpthread -lmpi_f90 -lmpi_f77 -lgfortran -lm -lm -lm
-lm -lmpi_cxx -lstdc++ -lmpi_cxx -lstdc++ -ldl -lmpi -lopen-rte -lopen-pal
-lnsl -lutil -lgcc_s -lpthread -ldl
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111021/0c3a8504/attachment-0001.htm>
