[petsc-users] PETSC-LINK- Error-Using Complex Types
Chetan Jhurani chetan.jhurani at gmail.com
Fri Oct 21 09:07:28 CDT 2011
You may be using a runtime link library for your visual studio
project that is incompatible with what petsc used to build.
This could be either due to debug/release choices or static/dynamic/
dynamic-multithreaded choices (or both).
See http://msdn.microsoft.com/en-us/library/abx4dbyh%28v=vs.80%29.aspx
as a starting point and compare the flags in your configure.log.  I
think petsc uses /MT by default, which is "Multithreaded, static link".
Chetan
> -----Original Message-----
> From: petsc-users-bounces at mcs.anl.gov [mailto:petsc-users-bounces at mcs.anl.gov] On Behalf Of PEREZ
> CERQUERA MANUEL RICARDO
> Sent: Friday, October 21, 2011 9:25 AM
> To: petsc-users at mcs.anl.gov; petsc-maint at mcs.anl.gov
> Subject: [petsc-users] PETSC-LINK- Error-Using Complex Types
> Hi all
> I build the complex version of Petsc. I used Microsoft
> Visual Stud . Run Petsc in this platform and got the
> following error:
> Error 1        error LNK2019: unresolved external symbol>
> __invalid_parameter_noinfo referenced in function
> "public:> char & __thiscall std::basic_string<char,struct>
> std::char_traits<char>,class std::allocator<char>>
> >::operator[](unsigned int)">
> (??A?$basic_string at DU?$char_traits at D@std@@V?$allocator at D@2@@std@@QAEAADI at Z)
>   libpetsc.lib(errtrace.o)
> Error	2	 error LNK2001: unresolved external symbol
> __invalid_parameter_noinfo	libpetsc.lib(err.o)
> Error	3	 error LNK2001: unresolved external symbol
> __invalid_parameter_noinfo	libpetsc.lib(plog.o)
> Error	4	 fatal error LNK1120: 1 unresolved
> externals	Debug\PAtreju.exe
> Could someone tell me  how to resolve it.
> Best regards Manuel
> Eng. Manuel Ricardo Perez Cerquera. MSc. Ph.D student
> Antenna and EMC Lab (LACE)
> Istituto Superiore Mario Boella (ISMB)
> Politecnico di Torino
> Via Pier Carlo Boggio 61, Torino 10138, Italy
> Email: manuel.perezcerquera at polito.it
> Phone: +39 0112276704
> Fax: +39 011 2276 299
