[petsc-users] KSPMonitorSingularValue
Klaij, Christiaan
C.Klaij at marin.nl
Fri Oct 21 02:48:47 CDT 2011
> If you just want to see the monitor, why not use the command line or
> PetscOptionsSetValue()?
I have three ksp's: one for the momentum eqs (GMRES) and one for
the pressure eq (CG) inside the SIMPLE preconditioner and one for
the matrix-free coupled mass-momentum system (FGMRES). The
command line shows me results for all but right now I'm only
interested in monitoring FGMRES on the coupled system.
> This is the code for setting up the monitor, you can call the part inside
> the if statement yourself if you like.
> ierr = PetscOptionsString("-ksp_monitor_singular_value","Monitor
> singular
> values","KSPMonitorSet","stdout",monfilename,PETSC_MAX_PATH_LEN,&flg);CHKERRQ(ierr);
> if (flg) {
> ierr = KSPSetComputeSingularValues(ksp,PETSC_TRUE);CHKERRQ(ierr);
> ierr =
> PetscViewerASCIIOpen(((PetscObject)ksp)->comm,monfilename,&monviewer);CHKERRQ(ierr);
> ierr =
> KSPMonitorSet(ksp,KSPMonitorSingularValue,monviewer,(PetscErrorCode
> (*)(void**))PetscViewerDestroy);CHKERRQ(ierr);
I'm still confused whether it is supposed to work with FGMRES,
the manual states only CG and GMRES. (Besides, I'm using fortran)
> How are you applying the action of the linear operator? If you use finite
> differencing, it could be inaccurate. Is this incompressible or a low-Mach
> compressible formulation? Try -ksp_monitor_true_residual, if the true
> residual drifts from the unpreconditioned residual computed by FGMRES, the
> Krylov space could be losing orthogonality. You can try
> -ksp_gmres_modifiedgramschmidt. Are you losing a lot of progress in
> restarts?
It's incompressible Navier-Stokes. No finite differencing, the
action is computed directly without approximations. It's right
preconditioning, so preconditioned and true residual should be
the same. I don't get any progress, the residual is stagnating
from the very first iteration way before any restart.
Regarding modified Gram Schmidt, I tried to set it as follows:
call KSPGMRESSetOrthogonalization(ksp,KSPGMRESModifiedGramSchmidtOrthogonalization,ierr)
But my compiler tells me:
This name does not have a type, and must have an explicit type. [KSPGMRESMODIFIEDGRAMSCHMIDTORTHOGONALIZATIO]
(petsc-3.1-p7, fortran with "use petscksp" and #include "finclude/petsckspdef.h")
dr. ir. Christiaan Klaij
CFD Researcher
Research & Development
E mailto:C.Klaij at marin.nl
T +31 317 49 33 44
MARIN
2, Haagsteeg, P.O. Box 28, 6700 AA Wageningen, The Netherlands
T +31 317 49 39 11, F +31 317 49 32 45, I www.marin.nl
