[petsc-users] KSPMonitorSingularValue
Thu Oct 20 10:21:25 CDT 2011
On Thu, Oct 20, 2011 at 10:15, Klaij, Christiaan <C.Klaij at marin.nl> wrote:
> The setting is Navier-Stokes, colocated FVM, matrix-free Krylov-Picard
> with SIMPLE preconditioning. It works for most case but stagnates
> for this particular case although SIMPLE as solver does converge nicely.
How are you applying the action of the linear operator? If you use finite
differencing, it could be inaccurate. Is this incompressible or a low-Mach
compressible formulation? Try -ksp_monitor_true_residual, if the true
residual drifts from the unpreconditioned residual computed by FGMRES, the
Krylov space could be losing orthogonality. You can try
-ksp_gmres_modifiedgramschmidt. Are you losing a lot of progress in
restarts?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111020/03b48916/attachment.htm>
