[petsc-users] Questions about TS
Wed Oct 19 11:05:46 CDT 2011
On Wed, Oct 19, 2011 at 3:54 PM, Blaise Bourdin <bourdin at math.lsu.edu>wrote:
> Hi,
> I am trying to use TS to solve a simple transient problem in an
> unstructured finite element f90 code.
> 1. Section 6.1.1 of the manual refers to a TSSetMatrices function that can
> be used to set the RHS and LHS matrices, but I can;t find it. Is this
> section outdated?
Yes. What you want is to use TSSetIFunction() and TSSetIJacobian(). Jed and
Sean have added some nice examples under TS
of this, and in the latest release there is a manual section.
Let us you know if these are unclear.
     Matt
2. Since we are using unstructured finite elements, the LHS matrix is not
> the identity. As far as I understand, we have two possible choices:
>   - Use a mass lumping approximation of the variational identity matrix
> (mass matrix), M, and use M^{-1}K for the RHS matrix instead of K.
>   - Use an IMEX method where the implicit matrix is the variational
> identity M.
>  Is this right? What is the recommended way?
> 3. Is src/ts/examples/tests/ex1f.F supposed to work? Is there a fortran or
> fortran90 example I could start from? I get the following:
> galerkin:tests bourdin$ ./ex1f -linear_constant_matrix
>           1  Procs Avg. error 2 norm                        NaN
>           NaN  euler
>           NaN  euler
> Thanks,
> Blaise
> Department of Mathematics and Center for Computation & Technology
> Louisiana State University, Baton Rouge, LA 70803, USA
> Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276
> http://www.math.lsu.edu/~bourdin
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111019/947ab979/attachment.htm>
