[petsc-users] Question on DMDA in example ex11f90
Wienand Drenth w.drenth at gmail.com
Wed Oct 19 05:29:19 CDT 2011
Hello,
Following suggestions on a previous query on handling distributed arrays, I
set forth to use the DMDA path.
I installed the latest petsc version (3.2 patch 3), and went looking into
example 11f90 (in src/dm/examples/tutorials) for inspiration.
Compilation of the example went ok, but when I run the example I get an
error:
12:25] examples/tutorials 81 > mpiexec -n 1 ex11f90
Vector Object:Vec_0x80b3bb8_0 1 MPI processes
  type: mpi
Process [0]
*** glibc detected *** ex11f90: free(): invalid pointer: 0x080b6630 ***
======= Backtrace: =========
/lib/libc.so.6[0xb6f438c4]
/lib/libc.so.6(cfree+0x90)[0xb6f47370]
/home/wdrenth/software/petsc-3.2-p3/linux-gnu/lib/libpetsc.so(PetscFreeAlign+0x1b)[0xb777f5b1]
/home/wdrenth/software/petsc-3.2-p3/linux-gnu/lib/libpetsc.so(VecDestroy_Seq+0x6a)[0xb7616e60]
1
2
3
4
0
/home/wdrenth/software/petsc-3.2-p3/linux-gnu/lib/libpetsc.so(VecDestroy+0x51)[0xb7976a11]
/home/wdrenth/software/petsc-3.2-p3/linux-gnu/lib/libpetsc.so(DMClearGlobalVectors+0x6c)[0xb7666064]
/home/wdrenth/software/petsc-3.2-p3/linux-gnu/lib/libpetsc.so(DMDestroy+0x233)[0xb76917d8]
/home/wdrenth/software/petsc-3.2-p3/linux-gnu/lib/libpetsc.so(dmdestroy_+0x1b)[0xb7692b5a]
ex11f90(MAIN__+0x172)[0x8049086]
ex11f90(main+0x27)[0x8049967]
/lib/libc.so.6(__libc_start_main+0xe0)[0xb6eee390]
ex11f90[0x8048eb1]
Petsc was installed with the following config options:
--PETSC_ARCH=${PETSC_ARCH} --with-mpi-dir=${MPI_DIR}
--download-f-blas-lapack=1 --with-shared-libraries=1 --with-debugging=no
--download-mumps=1 --with-mumps=1 --with-fortran-interfaces
--download-scalapack=1 --with-scalapack=1 --download-blacs=1 --with-blacs=1
--download-parmetis=1 --download-hypre=1
PETSC_ARCH is linux-gnu, and I have a locally installed MPI version, with
MPI_DIR being the location. I use the openmpi 1.4.3 version of MPI.
Thank for any support and help,
kind regards,
Wienand
Wienand Drenth PhD
Eindhoven, the Netherlands
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111019/0a031f57/attachment-0001.htm>
