[petsc-users] about linear solver convergence
behzad baghapour behzad.baghapour at gmail.com
Wed Oct 12 09:56:48 CDT 2011
I found that I should set up KSP in each Newton iteration ( if I don't want
to use SNES I think!).
Then KSP linear solver converged and my problem is solved.
By the way, Is it correct to re-setup KSP in each Newton iteration or I can
use a better way?
On Tue, Oct 11, 2011 at 7:45 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Oct 11, 2011 at 11:13 AM, behzad baghapour <
> behzad.baghapour at gmail.com> wrote:
>> Okey. I checked the condition number "max/min".
>> It increases significantly in each ksp iterations!!!
> The approximation is becoming better. The condition number is harder to
> actually compute than the solution.
> Bottom line: You have a hard problem. Iterative methods do not work on hard
> problems without specialized
> preconditioners. I recommend a literature search on solvers for your
> equations.
>    Matt
>> Is it correct when the Jacobian matrix is fixed for each ksp iterations or
>> it is due to my fault?
>> On Tue, Oct 11, 2011 at 7:28 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>>> On Tue, Oct 11, 2011 at 10:55, behzad baghapour <
>>>> OK. Then how I can calculate and monitor the "condition number" in ksp?
>>> -ksp_monitor_singular_value
>> Behzad Baghapour
>> Ph.D. Candidate, Mechecanical Engineering
>> University of Tehran, Tehran, Iran
>> https://sites.google.com/site/behzadbaghapour
>> Fax: 0098-21-88020741
> experiments lead.
> -- Norbert Wiener
Behzad Baghapour
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111012/361aa42d/attachment.htm>
