[petsc-users] Vec I/O using different parallel layout
Ethan Coon ecoon at lanl.gov
Tue Oct 11 10:56:55 CDT 2011
On Mon, 2011-10-10 at 17:31 -0700, Mohamad M. Nasr-Azadani wrote:
> A simple example for this case would be to write the runtime data
> (parallel vector) to file and then just load the saved vector to do
> some simple SERIAL post processing.
If this is your actual goal and the post-processing is not too
expensive, you may find it easier to use the matlab or numpy/python
scripts in $PETSC_DIR/bin/matlab and $PETSC_DIR/bin/pythonscripts
respectively.
Ethan
> Thanks in advance,
> Best
> Mohamad
Ethan Coon
Post-Doctoral Researcher
Applied Mathematics - T-5
Los Alamos National Laboratory
505-665-8289
http://www.ldeo.columbia.edu/~ecoon/
