[petsc-users] Vec I/O using different parallel layout
Mon Oct 10 19:45:06 CDT 2011
On Oct 10, 2011, at 7:41 PM, Mohamad M. Nasr-Azadani wrote:
> Thanks Barry,
> I am still not 100% sure if I can do this.
> Say I have save the global vector obtained by a DA (3D) that is shared amongst 16 processors.
> Can I load that data into a vector obtained from a DA (3D, same size obviously) that is shared on 1 processor?
  ABSOLUTELY. Or a DA on 2 processes etc.
   Barry
> Thanks,
> Best,
> Mohamad
> On Mon, Oct 10, 2011 at 5:36 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Oct 10, 2011, at 7:31 PM, Mohamad M. Nasr-Azadani wrote:
> > Hi
> > I was wondering if it would be possible if I write a global vector (associated with a certain 3D distributed array)  to file
> > via:
> >             ierr = PetscViewerBinaryOpen(PCW1, filename, FILE_MODE_WRITE, &writer);
> >             ierr = VecView(vec_data, writer);
> >             ierr = PetscViewerDestroy(writer);
> > And then load the data into a global vector which is not created using the same parallel layout?
> > A simple example for this case would be to write the runtime data (parallel vector) to file and then just load the saved vector to do some simple SERIAL post processing.
>  YES.
>   The vector is saved to the file in the "natural ordering" that is starting with the logically 0,0,0 coordinate then increasing through the x axis, then the y axis then the z axis. To load back in in parallel you need to pass to VecLoad() a vector obtained with the appropriate DMCreateGlobalVector().
>  Barry
> > Thanks in advance,
> > Best
> > Mohamad
