[petsc-users] Domain partitioning using DAs
Mohamad M. Nasr-Azadani mmnasr at gmail.com
Sun Oct 9 03:19:59 CDT 2011
Thanks Barry and Jed.
That definitely helps.
Best,
Mohamad
On Sat, Oct 8, 2011 at 6:32 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Sat, Oct 8, 2011 at 07:27, Mohamad M. Nasr-Azadani <mmnasr at gmail.com>wrote:
>> Thanks Jed. I guess the whole point I am missing is in that "squarish".
>> I, for instance, use two processors for a domain of the global size:
>> nx=50
>> ny=40
>> nz=4
>> To my surprise, the way it was decomposed was in y-direction, i.e.
>> processor 0:
>> 0-49
>> 0-19
>> 0-3
>> processor 1:
>> 0-49
>> 20-39
>> 0-3
>> and not x-direction which minimizes the surface area between the two
>> processors.
>> Obviously "2" is a prime number. In that case, is PETSc biased to choose
>> any of the directions?
> There is an order to which directions get tried, but it will never pick a
> split that is "too bad". If you run on four processes, it will split in both
> the X and Y directions. The complete code is here.
> http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-dev/src/dm/impls/da/da3.c.html#line231
> I'm a little surprised it doesn't find the "best" split in this simple
> case.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111009/9bef8a05/attachment.htm>
