[petsc-users] KSP and VecDestroy
Fri Oct 7 19:49:35 CDT 2011
On Fri, Oct 7, 2011 at 19:48, Shiyuan <gshy2014 at gmail.com> wrote:
> Hi,
>    I want to track down an memory problem and have something I don't
> understand.
> In the following part, I create four vectors and destroy them. If I don't
> call KSPSolve, log tells me four Vec are created and four Vec are destroyed
> which I expect. But if I call KSPSolve, log tells me four Vec are created
> but only two are destroyed in that Stage? Does KSP refer the two vectors
> somewhere inside which make VecDestroy cannot destroy them?
Yes
> Does it create memory leak becase of that?
No, they are destroyed when you call KSPDestroy().
> Thanks.
>     ierr=PetscLogStagePush(memoryWatch);CHKERRQ(ierr);
>     MatGetVecs(*(pCSolverNeu->pK),&x0,&rhs);
> VecDuplicate(x0,&(workVec[0]));VecDuplicate(x0,&(workVec[1]));
>     VecSetRandom(x0,randomctx);
>     VecCopy(x0,workVec[0]);
>     MatMult(*(pMGDataVec[0]->pA),x0,rhs);
>     ierr=KSPSolve(ksp,rhs, workVec[0]);CHKERRQ(ierr);
>     ierr=VecDestroy(&x0);CHKERRQ(ierr);
>     ierr=VecDestroy(&rhs);CHKERRQ(ierr);
>     ierr=VecDestroy(&workVec[0]);CHKERRQ(ierr);
>     ierr=VecDestroy(&workVec[1]);CHKERRQ(ierr);
>     ierr=PetscLogStagePop();CHKERRQ(ierr);
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111007/71ef090f/attachment.htm>
