[petsc-users] compiling petsc.h and cusp's headers
Tue Oct 4 21:30:55 CDT 2011
On Tue, Oct 4, 2011 at 6:59 PM, Shiyuan <gshy2014 at gmail.com> wrote:
> *>*  Are you using the PETSc makefiles to compile it? Or did you make up that
> *>* compile line yourself? Why not just use the PETSc makefile to compile it?
> Actually, the compiling command I usedd is generated by
> PETSs's makefiles.* *But I am looking for something like "make  getincludedirs; make getpetscflags;
> make getlinklibs" which can give me the compiling flags Petsc uses to feed nvcc. Are there anything
> like that?
> *>*  Presumably cusp/thrust has some pattern for what include files need to be
> *>* included in what order. If you do not know the pattern then why not start by
> *>* copying what PETSc does, since that compiles? For example
> *>* cuspvecimpl.h has
> *>* #include <cublas.h>
> *>* #include <cusp/blas.h>
> *>* #include <thrust/device_vector.h>
> *>* #include <thrust/iterator/constant_iterator.h>
> *>* #include <thrust/transform.h>
> *>* #include <thrust/iterator/permutation_iterator.h>
> *>* while cuspmatimpl.h has
> *>* #include <../src/vec/vec/impls/seq/seqcusp/cuspvecimpl.h>
> *>* #include <cusp/csr_matrix.h>
> *>* #include <cusp/multiply.h>
> *>* /*for MatCreateSeqAIJCUSPFromTriple*/
> *>* #include <cusp/coo_matrix.h>
> *>* so start with at least those.   Generally just picking a couple of random
> *>* include files from some C++ package (like cusp/thrust)  and including them
> * won't work.
> I did check the documentation of cusp, and I don't see a requirement about
> **the order for including headers. It doesn't sound reasonable to require programmers to enforce the order when the programmers
> uses only functions from one library. Does it?( I think there is an issue I don't see, please excuse me for my ignorance). And I did
> try a few experiment where I picked some cusp examples and changed the orders of including headers, and they do work.
> >I believe that your problem is the clash of VecType between CUSP and PETSc.
> >In aijcusp.cu, we have
> >#undef VecType
> >#include "../src/mat/impls/aij/seq/seqcusp/cuspmatimpl.h"
>  >   Matt
> That explains it. But I still don't get the solution. If I want to define a function where I call some functions provided by Petsc and some functions  provided by cusp and thrust,
> In what order should I include the headers? For example, if I want Mat, Vec and cusp::krylov::cg.
>  If I look at the aijcusp.cu where MatMult_SeqAIJCusp is defined, it has a long list of headers,
> #include "petscconf.h"
> PETSC_CUDA_EXTERN_C_BEGIN
> #include "../src/mat/impls/aij/seq/aij.h" /*I "petscmat.h" I*/
> #include "petscbt.h"
> #include "../src/vec/vec/impls/dvecimpl.h"
> #include "private/vecimpl.h"
> PETSC_CUDA_EXTERN_C_END
> #undef VecType
> #ifdef PETSC_HAVE_TXPETSCGPU
> #include "csr_matrix_data.h"
> #include "csr_matrix_data_gpu.h"
> #include "csr_tri_solve_gpu.h"
> #include "csr_tri_solve_gpu_level_scheduler.h"
> #include "csr_spmv_inode.h"
> #include <algorithm>
> #include <vector>
> #include <string>
> #include <thrust/sort.h>
> #include <thrust/fill.h>
> But looking at this list of headers, I cannot see what files do I really need and what else is missing if I only want Mat, Vec and cusp::krylov::cg.
> Is there a less painful way? Thanks.
> <include PETSc headers>
#undef VecType
<include CUSP headers you want>
   Matt
> Shiyuan
> **>* On Oct 4, 2011, at 2:07 PM, Shiyuan wrote:
> *>* > Hi,
> *>* >    I cannot compiling a source file with petsc.h and cusp headers like
> *>* the following:
> *>* > #include"petsc.h"
> *>* > #include<iostream>
> *>* > #include "cusp/csr_matrix.h"
> *>* > #include <cusp/krylov/cg.h>
> *>* > int main(void){
> *>* >     std::cout<<"Hello World!"<<std::endl;
> *>* >     return 0;
> *>* > I use the following  to compile it:
> *>* > nvcc  -m64 -O -arch=sm_13  -c --compiler-options="-Wall -Wwrite-strings
> *>* -Wno-strict-aliasing -Wno-unknown-pragmas -O
> *>* -I/home/guest/sgu1/softwares/petsc-dev/include
> *>* -I/home/guest/sgu1/softwares/petsc-dev/helena-cxx-nompi-os64-release/include
> *>* -I/usr/local/cuda/include -I/home/guest/sgu1/softwares/cusp-library/
> *>* -I/home/guest/sgu1/softwares/thrust/
> *>* -I/home/guest/sgu1/softwares/petsc-dev/include/mpiuni  -DCUDA=1
> *>* -I/home/guest/sgu1/softwares/slepc-dev
> *>* -I/home/guest/sgu1/softwares/slepc-dev/helena-cxx-nompi-os64-release/include
> *>* -I/home/guest/sgu1/softwares/slepc-dev/include
> *>* -I/home/guest/sgu1/softwares/ImageMagick-6.7.2/include/ImageMagick
> *>*  -D__INSDIR__= -I/home/guest/sgu1/softwares/slepc-dev
> *>* -I/home/guest/sgu1/softwares/slepc-dev/include" MyKspTmp4.cu -o MyKspTmp4.o
> *>* > and it gives me error:
> *>* /usr/local/cuda/include/thrust/detail/device/cuda/detail/b40c/vector_types.h(37):
> *>* error: expected an identifier
> *>* > I think I did not do it in a correct way. I took a a look at some of
> *>* petsc's .cu files, they usually include a  long list of headers. Can petsc.h
> *>* directly included in a source code with cusp headers? What's the correct way
> *>* to do it?  Does the makefile system in petsc provide the command or flags to
> *>* do that? How can I obtain those flags?
> *>* > And after I compile it and obtain .o files, can I use g++ to link the .o
> *>* files with petcs libs and other .o files as usual, i.e.,
> *>* >     g++ -o $(BIN_DIR)/$@ $(CPPFLAGS) $@.s $(objects) $(PETSC_LIB)
> *>* $(OTHERS)
> *>* > or I need to do some extra steps and some specific linking flags to do
> *>* that?
> *>* > Thanks.
> *>* > Shiyuan
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111004/ebd80acb/attachment.htm>
