[petsc-users] compiling petsc.h and cusp's headers
Matthew Knepley
knepley at gmail.com
Tue Oct 4 15:36:22 CDT 2011
On Tue, Oct 4, 2011 at 3:15 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Are you using the PETSc makefiles to compile it? Or did you make up that
> compile line yourself? Why not just use the PETSc makefile to compile it?
> Presumably cusp/thrust has some pattern for what include files need to be
> included in what order. If you do not know the pattern then why not start by
> copying what PETSc does, since that compiles? For example
> cuspvecimpl.h has
> #include <cublas.h>
> #include <cusp/blas.h>
> #include <thrust/device_vector.h>
> #include <thrust/iterator/constant_iterator.h>
> #include <thrust/transform.h>
> #include <thrust/iterator/permutation_iterator.h>
> while cuspmatimpl.h has
> #include <../src/vec/vec/impls/seq/seqcusp/cuspvecimpl.h>
> #include <cusp/csr_matrix.h>
> #include <cusp/multiply.h>
> /*for MatCreateSeqAIJCUSPFromTriple*/
> #include <cusp/coo_matrix.h>
> so start with at least those. Generally just picking a couple of random
> include files from some C++ package (like cusp/thrust) and including them
> won't work.
I believe that your problem is the clash of VecType between CUSP and PETSc.
In aijcusp.cu, we have
#undef VecType
#include "../src/mat/impls/aij/seq/seqcusp/cuspmatimpl.h"
Matt
> Barry
> On Oct 4, 2011, at 2:07 PM, Shiyuan wrote:
> > Hi,
> > I cannot compiling a source file with petsc.h and cusp headers like
> the following:
> > #include"petsc.h"
> > #include<iostream>
> > #include "cusp/csr_matrix.h"
> > #include <cusp/krylov/cg.h>
> > int main(void){
> > std::cout<<"Hello World!"<<std::endl;
> > return 0;
> > I use the following to compile it:
> > nvcc -m64 -O -arch=sm_13 -c --compiler-options="-Wall -Wwrite-strings
> -Wno-strict-aliasing -Wno-unknown-pragmas -O
> -I/home/guest/sgu1/softwares/petsc-dev/include
> -I/home/guest/sgu1/softwares/petsc-dev/helena-cxx-nompi-os64-release/include
> -I/usr/local/cuda/include -I/home/guest/sgu1/softwares/cusp-library/
> -I/home/guest/sgu1/softwares/thrust/
> -I/home/guest/sgu1/softwares/petsc-dev/include/mpiuni -DCUDA=1
> -I/home/guest/sgu1/softwares/slepc-dev
> -I/home/guest/sgu1/softwares/slepc-dev/helena-cxx-nompi-os64-release/include
> -I/home/guest/sgu1/softwares/slepc-dev/include
> -I/home/guest/sgu1/softwares/ImageMagick-6.7.2/include/ImageMagick
> -D__INSDIR__= -I/home/guest/sgu1/softwares/slepc-dev
> -I/home/guest/sgu1/softwares/slepc-dev/include" MyKspTmp4.cu -o MyKspTmp4.o
> > and it gives me error:
> /usr/local/cuda/include/thrust/detail/device/cuda/detail/b40c/vector_types.h(37):
> error: expected an identifier
> > I think I did not do it in a correct way. I took a a look at some of
> petsc's .cu files, they usually include a long list of headers. Can petsc.h
> directly included in a source code with cusp headers? What's the correct way
> to do it? Does the makefile system in petsc provide the command or flags to
> do that? How can I obtain those flags?
> > And after I compile it and obtain .o files, can I use g++ to link the .o
> files with petcs libs and other .o files as usual, i.e.,
> > g++ -o $(BIN_DIR)/$@ $(CPPFLAGS) $@.s $(objects) $(PETSC_LIB)
> $(OTHERS)
> > or I need to do some extra steps and some specific linking flags to do
> that?
> > Thanks.
> > Shiyuan
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111004/2654d299/attachment.htm>
