[petsc-users] [SPAM] user experience with PCNN
Jakub Sistek sistek at math.cas.cz
Mon Oct 3 10:13:20 CDT 2011
Dear PETSc developers and users,
we are using PETSc to solve systems arising from mixed-hybrid FEM
applied to Darcy flow. First, the saddle point system is reduced to the
Schur complement problem for Lagrange multipliers on element interfaces,
which is then symmetric positive definite. Currently, we are using the
PCASM preconditioner to solve it. We have very positive experience (also
from other projects) with PCASM, but we have observed some worsening of
convergence and scalability with going to larger number of processors
(up to 64) here. As far as we understand, the increasing number of
iterations may be caused by the lack of coarse correction in the
implementation of the preconditioner. On the other hand, PCNN should
contain such a coarse solve. I have modified our FEM code to support
MATIS matrices besides MPIAIJ, but so far have a mixed experience with
PCNN. It seems to work on 2 CPUs, but complains about singular local
problems (solved by MUMPS) on more. After some time spent by debugging (
though there are probably still many bugs left in my code ) and
unsuccessful playing with some of the related options (
-pc_is_damp_fixed,  -pc_is_set_damping_factor_floating, etc.) I have
decided to ask couple of questions before I will continue in further
investigation why PCNN does not work for me for general case:
1) Am I right that PCNN is the only domain decomposition method
exploiting coarse correction readily available in PETSc?
2) As PCNN seems much less documented (I have found no example or so)
than other preconditioners, I would simply like to know if someone else
uses it and have positive experience with this implementation?
3) What may be proper options for stabilizing solutions of the local
problems?
4) Are there limitations to the method with respect to nullspace type of
subdomain problems, i.e. equation?
5) Do these answers depend on version of PETSc? (I have played with 3.0,
would things be different with 3.2 ?)
In the long run, I would like to connect the FEM code to an own solver
based on BDDC domain decomposition, for which the MATIS matrix seems as
a natural format and connection should be straightforward. However, I
would like to make it work with PCNN as well.
Thank you very much for your help and suggestions.
Best regards,
Jakub
Jakub Sistek, Ph.D.
postdoctoral researcher
Institute of Mathematics of the AS CR
http://www.math.cas.cz/~sistek/
tel: (+420) 222 090 710
