[petsc-users] check if object was created
Sun Oct 2 11:07:26 CDT 2011
On Oct 2, 2011, at 10:35 AM, Jed Brown wrote:
> On Sun, Oct 2, 2011 at 04:46, Dominik Szczerba <dominik at itis.ethz.ch> wrote:
> if(object)
>   KSP/Mat/Vec/etcDestroy(object)
> Just call KSPDestroy(&ksp);
> It doesn't matter if KSP is NULL or a valid object because this function checks. But note that if you just write
> KSP ksp;
> or allocate similarly in part of malloc() --- with no memzero() or similar --- then the value of ksp is undefined.
   In other words, if you are sometimes not sure if you will ever create a certain object make sure you initialize it to 0 with
   Vec vec = 0;
    VecDestroy(&vec);
     Note that we pass &vec as the argument and all the destroys set the value to 0 so it cannot be accidently used again.
   Barry
