[petsc-users] How to get Matrix from MatGetArray()
Sat Oct 1 10:26:30 CDT 2011
On Sat, Oct 1, 2011 at 10:23 AM, behzad baghapour <
behzad.baghapour at gmail.com> wrote:
> I meant by MatAssembly, the global indices of matrix elements (related to a
> dense format) which is changed into sparse one. So what would be right
> pattern to read the content of the Matrix from MatGetArray if I know that
> the original matrix is created by AIJ?
MatGetArray() on an AIJ matrix will give you 'A'. What do you need this for?
There are usually much
better ways to do things, and keep your code data-structure neutral.
   Matt
> On Sat, Oct 1, 2011 at 4:21 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>>  On Sat, Oct 1, 2011 at 00:39, behzad baghapour <
>>> I just be able to get right answer from MatGetArray( A, &a ) only if I
>>> define matrix in Dense fromat.
>>> How could I get the right Answer from this function when I define
>>> SparseAIJ matrix?
>> Depends what you mean by "right answer". This function accesses private
>> storage, so it's different for each matrix format. You might want to look at
>> MatView() or MatConvert().
> Behzad Baghapour
> Ph.D. Candidate, Mechecanical Engineering
> University of Tehran, Tehran, Iran
> https://sites.google.com/site/behzadbaghapour
> Fax: 0098-21-88020741
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111001/daaf986c/attachment.htm>
