[petsc-users] problems with MatCreateSeqAIJWithArrays
Nisoli Isaia
isaia.nisoli at gmail.com
Tue Nov 29 06:12:25 CST 2011
Sorry, I mixed up things.
It is probably simply
rowindices[size]=rowindices[size-1];
Is it?
Isaia
On Tue, Nov 29, 2011 at 9:48 AM, Nisoli Isaia <isaia.nisoli at gmail.com>wrote:
> So, if I want to add another row, what I should do is that:
> rowindices[size-1]=size+1;
> is this last line right?
> When a CSR matrix has a line 'i' which contains only 0s, how should I set
> rowindices[i]?
> Is there any place where the number of columns is taken into account in
> *PetscInt* rowindices;**PetscInt* colindices;**PetscScalar* values;*
> reading the documentation about CSR, it does not look like that.
> Thank you again
> Isaia
> On Mon, Nov 28, 2011 at 11:30 PM, Nisoli Isaia <isaia.nisoli at gmail.com>wrote:
>> >>* int convertPETSc(srmatrix &sA, Mat * const Aaddr)*>>* {*>>* PetscErrorCode ierr;*>>* PetscInt size=(sA.A).size1();*>>* unsigned int totnnz=(sA.A).nnz();*>>**>>* (sA.A).complete_index1_data();*>>* long unsigned int *row_ptr =(sA.A).index1_data().begin();*>>* long unsigned int *col_ptr =(sA.A).index2_data().begin();*>>* double * value_ptr = (sA.A).value_data().begin();*>>* unsigned int sizerow_ptr=(sA.A).index1_data().size();*>>* unsigned int sizecol_ptr=(sA.A).index2_data().size();*>>* PetscInt* rowindices;*>>* PetscInt* colindices;*>>* PetscScalar* values;*>>* rowindices=new PetscInt[sizerow_ptr];*>>**
>> >This array is probably one too short. It needs to have length nrows+1 (so
>> >that the length of the last row is known).
>> I tried
>> *rowindices=new PetscInt[sizerow_ptr+1];
>> *allocating some more memory is not a problem...
>> but I get the same error.
>> >>* colindices=new PetscInt[sizecol_ptr];*>>* values=new PetscScalar[totnnz];*>>* for (unsigned int i=0;i<sizerow_ptr;i++)*>>* rowindices[i]=PetscInt(row_ptr[i]);*>>* for (unsigned int i=0;i<sizecol_ptr;i++)*>>* colindices[i]=PetscInt(col_ptr[i]);*>>* for (unsigned int i=0;i<totnnz;i++)*>>* values[i]=PetscScalar(value_ptr[i]);*>>**>>* ierr=MatCreateSeqAIJWithArrays(PETSC_COMM_WORLD,size+1,size+1,rowindices,colindices,values,Aaddr);CHKERRQ(ierr);*>>**
>> >You haven't explained your API, but you have a lot of "size" things running
>> >around. You should probably pass in "size" here instead of "size+1".
>> I'm sorry, I didn't say that in the first mail, but I want the function to add one last row and one last column of zeros to the matrix.
>> So that the output matrix is (size+1)*(size+1) if the input matrix is size*size.
>> >* ierr=MatAssemblyBegin(*Aaddr,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);*>* ierr=MatAssemblyEnd(*Aaddr,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);*>* return 0;*>* }*>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111129/880db7f3/attachment.htm>
