[petsc-users] configure with --with-blacs-dir
    Alexander Grayver
    agrayver at gfz-potsdam.de
    Tue Nov 29 03:27:30 CST 2011
Hi PETSc team and others,
I am trying to configure PETSc with the following line:
./configure --with-petsc-arch=openmpi-intel-complex-debug-f-mumps
--with-fortran-interfaces=1 --download-mumps --download-parmetis
--with-scalapack-dir=/opt/intel/Compiler/11.1/072/mkl/lib/em64t
--with-blacs-dir=/opt/intel/Compiler/11.1/072/mkl/lib/em64t
--with-mpi-dir=/opt/mpi/intel/openmpi-1.4.2 --with-scalar-type=complex
--with-blas-lapack-dir=/opt/intel/Compiler/11.1/072/mkl/lib/em64t
--with-precision=double
And it tells me:
  TESTING: check from
config.libraries(config/BuildSystem/config/libraries.py:133)
          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
for details):
--with-blacs-dir=/opt/intel/Compiler/11.1/072/mkl/lib/em64t did not work
And I see in configure.log (full version is attached):
sh:
Possible ERROR while running linker: ld: cannot find -lblacs
  output: ret = 256
error message = {ld: cannot find -lblacs
Even though in specified directory there are:
libmkl_blacs_ilp64.a
libmkl_blacs_intelmpi_ilp64.a
libmkl_blacs_intelmpi_ilp64.so
libmkl_blacs_intelmpi_lp64.a
libmkl_blacs_intelmpi_lp64.so
libmkl_blacs_lp64.a
libmkl_blacs_openmpi_ilp64.a
libmkl_blacs_openmpi_lp64.a
libmkl_blacs_sgimpt_ilp64.a
libmkl_blacs_sgimpt_lp64.a
So what else do I need?
Thanks in advance.
Alexander
Type: application/x-zip-compressed
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111129/3ddd406b/attachment-0001.bin>
