[petsc-users] Error compiling code when upgrading from 3.1p8 to 3.2p5
TAY wee-beng
zonexo at gmail.com
Sun Nov 27 15:38:35 CST 2011
Got it! Thanks!
Yours sincerely,
TAY wee-beng
On 27/11/2011 10:30 PM, Satish Balay wrote:
> check http://www.mcs.anl.gov/petsc/documentation/changes/32.html
> -> Changed PetscTruth to PetscBool
> satish
> On Sun, 27 Nov 2011, TAY wee-beng wrote:
>> Hi,
>> I have trouble compiling my Fortran codes when I upgrade PETSc from 3.1p8 to
>> 3.2p5.
>> My code is something like this:
>> module global_data
>> use nrtype
>> implicit none
>> save
>> #include "finclude/petsc.h90"
>> !grid variables
>> integer :: size_x,size_y,size_z,grid_type
>> !size_x1,size_x2,size_x3,size_y1,size_y2,size_y3
>> real(8), allocatable ::
>> x(:),y(:),z(:),xu(:),yu(:),zu(:),xv(:),yv(:),zv(:),xw(:),yw(:),zw(:),c_cx(:),cu_cx(:),c_cy(:),cv_cy(:),c_cz(:),cw_cz(:)
>> !solver variables
>> I tried after compiling with the new 3.2p5 and got the following error:
>> /opt/openmpi-1.5.3/bin/mpif90 -c -g -debug all -implicitnone -warn unused
>> -fp-stack-check -heap-arrays -ftrapuv -check pointers -O0 -save -w90 -w -w95
>> -O0 -I/home/wtay/Lib/petsc-3.2-p5_mumps_debug/include
>> -I/home/wtay/Lib/petsc-3.2-p5_mumps_debug/include -I/opt/openmpi-1.5.3/include
>> -o global.o global.F90
>> global.F90(205): error #5082: Syntax error, found IDENTIFIER 'FLGG' when
>> expecting one of: ( % : . = =>
>> PetscTruth flgg
>> global.F90(205): error #6274: This statement must not appear in the
>> specification part of a module
>> PetscTruth flgg
>> global.F90(207): error #6236: A specification statement cannot appear in the
>> executable section.
>> integer(kind=selected_int_kind(5)) reason
>> global.F90(209): error #6236: A specification statement cannot appear in the
>> executable section.
>> integer(kind=selected_int_kind(10)) i_vec
>> global.F90(213): error #6236: A specification statement cannot appear in the
>> executable section.
>> integer ::
>> myid,num_procs,ksta,kend,ksta_ext,kend_ext,ksta_ext0,ksta2,kend2,kend3
>> global.F90(215): error #6236: A specification statement cannot appear in the
>> executable section.
>> integer ::
>> ijk_sta_p,ijk_end_p,ijk_sta_m,ijk_end_m,ijk_sta_mx,ijk_end_mx,ijk_sta_my,ijk_end_my,ijk_sta_mz,ijk_end_mz
>> global.F90(217): error #6236: A specification statement cannot appear in the
>> executable section.
>> character(2) :: procs
>> global.F90(205): error #6404: This name does not have a type, and must have an
>> explicit type. [PETSCTRUTH]
>> PetscTruth flgg
>> explicit type. [FLGG]
>> PetscTruth flgg
>> global.F90(229): error #6404: This name does not have a type, and must have an
>> explicit type. [KSTA]
>> ksta=myid*(size_z/num_procs)+1; kend=(myid+1)*(size_z/num_procs)
>> May I know what's wrong?
>> Thanks!
