[petsc-users] Get Stuck in SNES
Thu Nov 24 05:09:43 CST 2011
On Thu, Nov 24, 2011 at 5:00 AM, behzad baghapour <
behzad.baghapour at gmail.com> wrote:
> On Wed, Nov 23, 2011 at 4:33 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> On Wed, Nov 23, 2011 at 01:06, behzad baghapour <
>>>     for( c=0; c<ne; c++ ) for( p=0; p<tot; p++ )
>>>     FC->e[c].Q[p] = xx[c*(noe*num)+p];
>> You haven't told me about "noe" or "num". Do you mean for this to read
>> xx[c*tot+p]?
> noe is the number of equations (equal to number of flow states) and num is
> the number of shape functions in element (according to the order of
> accuracy)
>>>     ierr = VecRestoreArray( x, &xx ); CHKERRQ( ierr );
>>>     interiorFlux( FC->flw, FC->e );
>>>     faceFlux    ( FC->flw, FC->f, FC->e );
>> The first of these should set FC->e (if you are adding into it, then you
>> need to zero it first) and the second should add into it.
> I found that my mistake is that I forgot to set upwind effect in my
> defined field context. The problem was not stable, it is not related to
> SNES setup.
> However, I can't find out the difference between "basic" and
> "basicnonorms" in line search method.
Basic takes the full Newton step, but checks for decrease. nonorms just
takes it and moves on.
> In addition, Is it possible to set the number of line-search corrections
> or is just decided by the solver?
You can set a custom line search. I am not sure what you mean by this
"number of line search correctons"
   Matt
> Thanks a lot,
> BehZad
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111124/ecc40028/attachment.htm>
