[petsc-users] is something wrong with nnz ?
jean-frederic thebault jean-frederic at thebault-net.com
Wed Nov 23 10:37:06 CST 2011
Well, actually, when I call MatSetFromOption, with the right arguments, the
whole simulation is running, but there are some PETSC-ERROR about nnz, and
when I comment the calling of MatSetFromOption, the simulation (program)
stop at the first calculation. This time, I'm putting in this email the
log-file with calling of MatSetFromOption (then with PETSC-ERROR on nnz)...
Le 23 novembre 2011 17:17, Satish Balay <balay at mcs.anl.gov> a écrit :
> Since you get a SEGV - I would suggest running the code in the
> debugger - to check where its crashing.
> Also run with valgrind to see where problems start.. Mostlikely the
> issues would be change in prototypes for PETSc functions - between
> releases.
> Satish
> On Wed, 23 Nov 2011, jean-frederic thebault wrote:
> > Thanks for your response.
> > Sorry about that, to reduce the size of the log file, unfortunetly, I did
> > took out the bad lines... In the out.log I've put in this email, I've
> make
> > sure there are...
> > Actually, I don't use MatSetOption, but MatSetFromOption instead.
> However,
> > when I called MatSetFromOption, the PETSC_COMM_WORLD was missing. But
> now,
> > it's getting worse !! (as you could see in the out.log included in this
> > email).
> > Le 23 novembre 2011 15:55, Jed Brown <jedbrown at mcs.anl.gov> a écrit :
> > >  On Wed, Nov 23, 2011 at 08:24, jean-frederic thebault <
> > > jean-frederic at thebault-net.com> wrote:
> > >> I'm wondering what's wrong in my code. I'm using PETSc to solve a
> linear
> > >> system, and willing to use a multi-processor computer. 9 years ago, I
> used
> > >> petsc-2.1.3 with success. Few weeks ago, I've update petsc with the
> 3.1-p8
> > >> version and made the necessary changes to work with. No problem. And
> > >> recently, I've migrate to petsc-3.2-p5. Compilation is OK. But when I
> do
> > >> simulation, now, I have some PETSC-ERROR in the log file, even using
> only
> > >> one processor (see the out.log file in this email).
> > > You are calling MatSetOption() with the wrong number of arguments. C
> > > compilers tell you about this, but Fortran compilers do not.
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatSetOption.html
> > >> However, I think I defined MatMPI and VecMPI correctly, according to
> the
> > >> doc. The log file tell that something wrong with the nnz which should
> not
> > >> be greater than row length (??).
> > > The log you sent does not say anything about nnz. Fix the call to
> > > MatSetOption().
> > >  And also, with the previous version of PETSc I've used, the were no
> > >> problem using -pc_type bjacobi and -sub_pc_type sor, juste to solve
> linear
> > >> system doing parallel computations and because SOR is not
> parallelized. But
> > >> now, when I use -pc_type bjacobi and -sub_pc_type sor, with 3 rank, I
> > >> experiment some convergence problem during my simulation.
> > > These options should do the same thing they used to do. Make sure you
> are
> > > assembling correctly. If it's still confusing, run the old and new
> code with
> > > -ksp_monitor_true_residual -ksp_converged_reason -ksp_view -pc_type
> > > bjacobi -sub_pc_type sor
> > > and send the output of both for us to look at.
> > > Also note that you can use -pc_type sor even in parallel. There are
> > > options for local iterations and full iterations.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111123/cd127ca4/attachment-0001.htm>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111123/cd127ca4/attachment-0001.obj>
