[petsc-users] Only one column is in the matrix after solving the inverse matrix
huyaoyu
huyaoyu1986 at gmail.com
Tue Nov 22 23:13:15 CST 2011
Hong,
Thank you for your help!
I tried the example code of petsc-3.2/src/mat/examples/tests/ex1.c.
But the result is the same. I attach the modified code and the
results here. I don't know what is the problem exactly. By the way I am
using PETSc on a 64bit ubuntu 11.04. I complied MPICH2 myself, made
symbolic links in the /usr/bin for mpicc, mpiexec etc, and configured
PETSc use the command line:
./configure --with-cc=mpicc --with-fc=mpif90 --download-f-blas-lapack=1
I break some lines of the code to avoid line wrapping in Evolution mail
program.
> You can take a look at examples
> petsc-3.2/src/mat/examples/tests/ex1.c, ex125.c and ex125.c.
> Hong
> On Tue, Nov 22, 2011 at 9:23 AM, Yaoyu Hu <huyaoyu1986 at gmail.com> wrote:
> > Hi, everyone,
> > I am new to PETSc, and I have just begun to use it together with slepc. It
> > is really fantastic and I like it!
> > It?was not from me but one of my colleges who wanted to solve an inverse of
> > a matrix, which had 400 rows and columns.
> > I know that it is not good to design a algorithm that has a process for
> > solving the inverse of a matrix. I just wanted to?give it a try. However,
> > things turned out wired. I followed the instructions on the FAQ web page of
> > PETSc, the one using MatLUFractor() and MatMatSolve(). After I finished the
> > coding, I tried the program. The result I got?was a matrix which only has
> > its first column but nothing else. I did not know what's happened. The
> > following is the codes I used.
=============Modified code begins=================
static char help[] = "Give the inverse of a matrix.\n\n";
#include <petscmat.h>
#include <iostream>
#include <fstream>
#undef __FUNCT__
#define __FUNCT__ "main"
#define DIMENSION 2
int main(int argc,char **args)
PetscErrorCode ierr;
PetscMPIInt size;
Mat A,CA; // CA is the copy of A
Mat RHS,XX; // XX is the inverse result
MatFactorInfo mfinfo;
PetscScalar* array_scalar =
new PetscScalar[DIMENSION*DIMENSION];
PetscScalar* array_for_RHS;
// clean the values of array_scalar
for(int i=0;i<DIMENSION*DIMENSION;i++)
array_scalar[i] = 0.0;
// set up the indices
int idxm[DIMENSION];
for(int i=0;i<DIMENSION;i++)
idxm[i] = i;
PetscInitialize(&argc,&args,(char *)0,help);
ierr = MPI_Comm_size(PETSC_COMM_WORLD,&size);CHKERRQ(ierr);
if (size != 1) SETERRQ(PETSC_COMM_WORLD,
1,"This is a uniprocessor example only!");
// RHS & XX
ierr = MatCreate(PETSC_COMM_WORLD,&RHS);CHKERRQ(ierr);
ierr =MatSetSizes(RHS,
PETSC_DECIDE,PETSC_DECIDE,
DIMENSION,DIMENSION);CHKERRQ(ierr);
ierr = MatSetType(RHS,MATDENSE);CHKERRQ(ierr);
ierr = MatSetFromOptions(RHS);CHKERRQ(ierr);
ierr = MatGetArray(RHS,&array_for_RHS); CHKERRQ(ierr);
array_for_RHS[i*DIMENSION + i] = 1.0;
ierr = MatRestoreArray(RHS,&array_for_RHS); CHKERRQ(ierr);
ierr = MatDuplicate(RHS,
MAT_DO_NOT_COPY_VALUES,&XX);CHKERRQ(ierr);
/* matrix A */
/* read in the file A.txt. It is a single process program so I think it
is OK to read a file like this.*/
std::fstream in_file;
double temp_scalar;
in_file.open("./A.txt",std::ifstream::in);
if(!in_file.good())
ierr = PetscPrintf(PETSC_COMM_SELF,
"File open failed!\n"); CHKERRQ(ierr);
return 1;
for(int j=0;j<DIMENSION;j++)
in_file>>temp_scalar;
array_scalar[i*DIMENSION + j] = temp_scalar;
in_file.close();
// matrices creation and initialization
ierr = MatCreateSeqDense(PETSC_COMM_WORLD,
DIMENSION,DIMENSION,PETSC_NULL,&A); CHKERRQ(ierr);
DIMENSION,DIMENSION,PETSC_NULL,&CA); CHKERRQ(ierr);
ierr = MatSetValues(A,DIMENSION,idxm,DIMENSION,idxm,
array_scalar,INSERT_VALUES); CHKERRQ(ierr);
ierr = MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY); CHKERRQ(ierr);
ierr = MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY); CHKERRQ(ierr);
// create CA
ierr = MatDuplicate(A,MAT_COPY_VALUES,&CA); CHKERRQ(ierr);
"The A matrix is:\n"); CHKERRQ(ierr);
ierr = MatView(A,PETSC_VIEWER_STDOUT_SELF); CHKERRQ(ierr);
// in-place LUFactor
ierr = MatLUFactor(A,0,0,0); CHKERRQ(ierr);
// solve for the inverse matrix XX
ierr = MatMatSolve(A,RHS,XX); CHKERRQ(ierr);
"The inverse of A matrix is:\n"); CHKERRQ(ierr);
ierr = MatView(XX,PETSC_VIEWER_STDOUT_SELF); CHKERRQ(ierr);
"The multiplied result is:\n"); CHKERRQ(ierr);
ierr = MatMatMult(CA,XX,MAT_REUSE_MATRIX,PETSC_DEFAULT,&RHS);
ierr = MatView(RHS,PETSC_VIEWER_STDOUT_SELF); CHKERRQ(ierr);
// destroy
ierr = MatDestroy(&A); CHKERRQ(ierr);
ierr = MatDestroy(&RHS); CHKERRQ(ierr);
ierr = MatDestroy(&XX); CHKERRQ(ierr);
ierr = MatDestroy(&CA); CHKERRQ(ierr);
ierr = PetscFinalize();
delete[] array_scalar;
return 0;
===========Modified code ends==============
The input file(DIMENSION = 2) and the results are
A.txt:
2.0 3.0
-20.0 55.0
Results:
The A matrix is:
Matrix Object: 1 MPI processes
type: seqdense
2.0000000000000000e+00 3.0000000000000000e+00
-2.0000000000000000e+01 5.5000000000000000e+01
type: seqdense
3.2352941176470590e-01 -0.0000000000000000e+00
1.1764705882352941e-01 0.0000000000000000e+00
type: seqdense
1.0000000000000000e+00 0.0000000000000000e+00
0.0000000000000000e+00 0.0000000000000000e+00
