[petsc-users] Memory for matrix assembly
Andrej Mesaros
andrej.mesaros at bc.edu
Tue Nov 22 08:30:25 CST 2011
Jed Brown wrote:
> On Mon, Nov 21, 2011 at 23:46, Andrej Mesaros <andrej.mesaros at bc.edu
> <mailto:andrej.mesaros at bc.edu>> wrote:
> My code has a function which, when given a fixed matrix row index,
> calculates one by one values of all non-zero matrix elements in this
> row, while also returning the column index of each of these
> elements. So, all I need to do is put that the 1st process has a
> loop for row index going from 1 to 60k, the 2nd process has the loop
> going from 60k+1 to 120k, etc. Inside the loops, the row index is
> given, so it finds the non-zero elements and their column indices.
> That is fine, but the error circumnstance indicated that a huge number
> of entries were being computed by a different process. It is possible
> that memory was corrupted earlier. You can try smaller problems with
> valgrind or -malloc_debug -malloc_dump, but if these don't work, it
> could be difficult to track down.
Given that I indeed call MatSetValues exclusively with row indices
within the range determined by MatGetOwnershipRange, it should be
impossible to generate entries on the wrong process, right? In such a
case, could the corruption you mention be somehow due to the way I call
other PETSc functions? Or is it at all possible that too small
preallocation is making a problem?
Also, what is the meaning of the memories in the report: "allocated",
"used by process" and "requested"? Still don't understand, and couldn't
find in the manual.
> To clarify, is "n" the matrix dimension? So that's memory for
> 100 vectors (the Krylov space) plus the memory already taken by
> PETSc when assembly is done?
> Yeah, roughly that used by PETSc plus those additional vectors needed by
> SLEPc.
