[petsc-users] Memory for matrix assembly
Andrej Mesaros andrej.mesaros at bc.edu
Mon Nov 21 23:46:58 CST 2011
Jed Brown wrote:
> On Mon, Nov 21, 2011 at 22:47, Andrej Mesaros <andrej.mesaros at bc.edu
> <mailto:andrej.mesaros at bc.edu>> wrote:
>     Dear all,
>     I need guidance in finding the memory needed for matrix assembly.
>     The job that fails when I reserve 3.5GB memory per node gives me the
>     error output below. The job was run on 96 nodes, each storing its
>     own part of a matrix (around 60k rows each, ~100M non-zero complex
>     entries).
>     The error occurs during assembly (similar numbers for every node):
>     [25]PETSC ERROR: Out of memory. This could be due to allocating
>     [25]PETSC ERROR: too large an object or bleeding by not properly
>     [25]PETSC ERROR: destroying unneeded objects.
>     [25]PETSC ERROR: Memory allocated 4565256864 <tel:4565256864> Memory
>     used by process
>     3658739712
>     [25]PETSC ERROR: Try running with -malloc_dump or -malloc_log for info.
>     [25]PETSC ERROR: Memory requested 980025524!
>     [25]PETSC ERROR:
>     ------------------------------__------------------------------__------------
>     [25]PETSC ERROR: Petsc Release Version 3.1.0, Patch 8, Thu Mar 17
>     13:37:48 CDT 2011
>     [25]PETSC ERROR: See docs/changes/index.html for recent updates.
>     [25]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>     [25]PETSC ERROR: See docs/index.html for manual pages.
>     [25]PETSC ERROR:
>     [25]PETSC ERROR: Unknown Name on a linux-gnu named compute-5-54.local by
>     mesaros Wed Oct 12 22:27:13 2011
>     [25]PETSC ERROR: Libraries linked from
>     /home/mesaros/code/petsc-3.1-__p8/linux-gnu-mpi-debug-__complex/lib
>     [25]PETSC ERROR: Configure run at Thu Jun 30 12:30:13 2011
>     [25]PETSC ERROR: Configure options --with-scalar-type=complex
>     --with-64-bit-indices=1 --download-f-blas-lapack=yes --download-mpich=1
>     --with-mpi-exec=/usr/publ$
>     [25]PETSC ERROR:
>     [25]PETSC ERROR: PetscMallocAlign() line 49 in src/sys/memory/mal.c
>     [25]PETSC ERROR: PetscTrMallocDefault() line 192 in src/sys/memory/mtr.c
>     [25]PETSC ERROR: PetscPostIrecvInt() line 250 in src/sys/utils/mpimesg.c
> Looks like you are trying to half a billion (--with-64-bit-indices) or a
> billion entries. How are you computing the nonzeros? Is it possible that
> many processes are computing entries that need to go to one process?
My code has a function which, when given a fixed matrix row index,
calculates one by one values of all non-zero matrix elements in this
row, while also returning the column index of each of these elements.
So, all I need to do is put that the 1st process has a loop for row
index going from 1 to 60k, the 2nd process has the loop going from 60k+1
to 120k, etc. Inside the loops, the row index is given, so it finds the
non-zero elements and their column indices.
>     [25]PETSC ERROR: MatStashScatterBegin_Private() line 498 in
>     src/mat/utils/matstash.c
>     [25]PETSC ERROR: MatAssemblyBegin_MPIAIJ() line 474 in
>     src/mat/impls/aij/mpi/mpiaij.c
>     [25]PETSC ERROR: MatAssemblyBegin() line 4564 in
>     src/mat/interface/matrix.c
>     Now, how much memory would I need per node for this assembly to
>     work? Is it "Memory allocated" + "Memory requested", which is around
>     5.5GB? And did it fail when "Memory used by process" reached ~3.5GB,
>     which was the limit for the job? Usually, breaking the limit on
>     memory per node kills the job, and PETSc then doesn't give the above
>     "Out of memory" output.
>     Additionally, can I simply estimate the additional memory needed for
>     SLEPc to find ~100 lowest eigenvalues?
> Start with what is typically needed by PETSc (the matrix, the setup cost
> is for your preconditioner, the vectors for the Krylov method) and add
> 100*n*sizeof(PetscScalar).
To clarify, is "n" the matrix dimension? So that's memory for 100
vectors (the Krylov space) plus the memory already taken by PETSc when
assembly is done?
Thanks a lot!
