[petsc-users] sqrt: DOMAIN error during run
TAY wee-beng zonexo at gmail.com
Mon Nov 21 13:10:50 CST 2011
I have extended my 2D CFD code to 3D.
When I tried to do a step by step debug using Compaq visual Fortran
(CVF) in windows, there is no error.
However, if I execute the code directly, the following error happens:
- sqrt: DOMAIN error
Image              PC        Routine            Line        Source
ibm2d_high_Re_wo_  00B95C69  Unknown               Unknown  Unknown
ibm2d_high_Re_wo_  00B95AC7  Unknown               Unknown  Unknown
ibm2d_high_Re_wo_  00B95C21  Unknown               Unknown  Unknown
ibm2d_high_Re_wo_  00B9CEA8  Unknown               Unknown  Unknown
ibm2d_high_Re_wo_  00BBF61D  Unknown               Unknown  Unknown
ibm2d_high_Re_wo_  00BB7E30  Unknown               Unknown  Unknown
ibm2d_high_Re_wo_  00BB1B98  Unknown               Unknown  Unknown
ibm2d_high_Re_wo_  00B79319  Unknown               Unknown  Unknown
ibm2d_high_Re_wo_  0085C29A  Unknown               Unknown  Unknown
ibm2d_high_Re_wo_  0063C656  Unknown               Unknown  Unknown
ibm2d_high_Re_wo_  008EC67D  Unknown               Unknown  Unknown
ibm2d_high_Re_wo_  005C95DC  Unknown               Unknown  Unknown
ibm2d_high_Re_wo_  00549D2C  Unknown               Unknown  Unknown
ibm2d_high_Re_wo_  00500BEE  Unknown               Unknown  Unknown
ibm2d_high_Re_wo_  00428FE3  Unknown               Unknown  Unknown
ibm2d_high_Re_wo_  00463073  Unknown               Unknown  Unknown
ibm2d_high_Re_wo_  00BC5309  Unknown               Unknown  Unknown
ibm2d_high_Re_wo_  00BB1035  Unknown               Unknown  Unknown
kernel32.dll       7C817067  Unknown               Unknown  Unknown
Incrementally linked image--PC correlation disabled.
I repeated running the code in Linux and calling "KSPGetConvergedReason"
gives:
P Diverged
Does anyone know why this error occurs? It's strange that the step by
step debug works and gives a reasonable solution but executing the code
gives error.
Also, when changing from 2D to 3D, is there any additional stuff I need
to add in besides adding another dimension?
Yours sincerely,
TAY wee-beng
