[petsc-users] Assembling primal Schur matrix in FETI-DP method
Thomas Witkowski
Thomas.Witkowski at tu-dresden.de
Mon Nov 21 09:00:27 CST 2011
Zitat von Jed Brown <jedbrown at mcs.anl.gov>:
> On Mon, Nov 21, 2011 at 08:03, Thomas Witkowski <
> Thomas.Witkowski at tu-dresden.de> wrote:
>> Okay, but how to make use of the KSP in MatMatSolve?
> With this approach, you just call KSPSolve() multiple times.
I have to multiple two matrices, one is implicitly defined by a KSP,
the other one is explicitly assembled. So when using KSPSolve(), it
must be called for each column of the second matrix? This seems not to
be very efficient as I thought the matrices are stored row wise? Is
there a way to get the columns of a SEQAIJ matrix?
Thomas
