[petsc-users] Get Stuck in SNES
behzad baghapour behzad.baghapour at gmail.com
Mon Nov 21 02:33:00 CST 2011
Dear Developers,
I've finished programming with SNES. But when I run, SNES just do one
Nonlinear iteration and comes out !!!
I check that the residual evaluation is correct BUT the linear solver may
not work while the number of linear iteration is "0". I also check that the
jacobian routine is called during process but I don't know how to check the
jacobian and preconditioner in SNES to ensure the correct values.
Here I want to know what procedure I should do and where is the beginning
point for debugging with SNES?
Thanks a lot,
BehZad
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111121/8cb8d413/attachment.htm>
