[petsc-users] Assembling primal Schur matrix in FETI-DP method
Thomas Witkowski
Thomas.Witkowski at tu-dresden.de
Fri Nov 18 07:53:08 CST 2011
Zitat von Jed Brown <jedbrown at mcs.anl.gov>:
> On Fri, Nov 18, 2011 at 07:02, Thomas Witkowski <
> thomas.witkowski at tu-dresden.de> wrote:
>> In my current FETI-DP implementation, the solution of the Schur complement
>> on the primal variables is done by an iterative solver. This works quite
>> good, but for small and mid size 2D problems I would like to test it with
>> direct assembling and inverting the Schur complement matrix. In my
>> notation, the matrix is defined by
>> S_PiPi = K_PiPi - K_PiB inv(K_BB) K_BPi
>> "Pi" are the primal and "B" the non-primal variables. K_BB is factorized
>> with a (local) direct solver (umpfack or mumps). But how can I create a
>> matrix from the last expression? Is there a way to do a matrix-matrix
>> multiplication in PETSc, where the first matrix is the (implicit defined)
>> dense inverse of a sparse matrix, and the second matrix is a sparse matrix?
>> Or is it required to extract the rows of K_BPi in some way and to perform
>> than a matrix-vector multiplication with inv(K_BB)?
> You should be able to construct the sparsity pattern of the resulting
> matrix, therefore you can color it and get the explicit operator by
> MatFDColoringApply() where the "base" vector is zero and the "function" is
> just MatMult().
> There should probably be a Mat function that does this for you given a
> known sparsity pattern.
Defining the sparsity pattern is no problem. But is there any
documentation on MatFDColoringApply? The online function reference is
quite short and is not mentioned in the manuel. So, I have no real
idea how this is related to my question.
Thomas
