[petsc-users] Assembling primal Schur matrix in FETI-DP method
Thomas Witkowski thomas.witkowski at tu-dresden.de
Fri Nov 18 07:02:54 CST 2011
In my current FETI-DP implementation, the solution of the Schur
complement on the primal variables is done by an iterative solver. This
works quite good, but for small and mid size 2D problems I would like to
test it with direct assembling and inverting the Schur complement
matrix. In my notation, the matrix is defined by
S_PiPi = K_PiPi - K_PiB inv(K_BB) K_BPi
"Pi" are the primal and "B" the non-primal variables. K_BB is factorized
with a (local) direct solver (umpfack or mumps). But how can I create a
matrix from the last expression? Is there a way to do a matrix-matrix
multiplication in PETSc, where the first matrix is the (implicit
defined) dense inverse of a sparse matrix, and the second matrix is a
sparse matrix? Or is it required to extract the rows of K_BPi in some
way and to perform than a matrix-vector multiplication with inv(K_BB)?
Thomas
