[petsc-users] Using petsc for banded matrices and 2D finite differences
Brandt Belson
bbelson at princeton.edu
Tue Nov 15 10:57:57 CST 2011
Thanks for getting back to me.
The matrix solves in each x-y plane are linear. The matrices depend on the
z wavenumber and so are different at each x-y slice. The equations are
basically Helmholtz and Poisson type. They are 3D, but when done in Fourier
space, they decouple so each x-y plane can be solved independently.
I'd like to run on a few hundred processors, but if possible I'd like it to
scale to more processors for higher Re. I agree that keeping the
z-dimension data local is beneficial for FFTs.
Brandt
On Tue, Nov 15, 2011 at 10:57 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Tue, Nov 15, 2011 at 09:43, Brandt Belson <bbelson at princeton.edu>wrote:
>> I'm writing a 3D incompressible fluids solver for transitional and
>> turbulent boundary layers, and would like to make use of petsc if possible.
>> At each time-step I'll need to solve matrix equations arising from finite
>> differences in two dimensions (x and y) on a structured grid. The matrix is
>> block tri/penta-diagonal, depending on the stencil, and the blocks are also
>> tri/penta-diagonal. Correct me if I'm wrong, but I believe these types of
>> matrix equations can be solved directly and cheaply on one node.
>> The two options I'm comparing are:
>> 1. Distribute the data in z and solve x-y plane matrices with LAPACK or
>> other serial or shared-memory libraries. Then do an MPI all-to-all to
>> distribute the data in x and/or y, and do all computations in z. This
>> method allows all calculations to be done with all necessary data available
>> to one node, so serial or shared-memory algorithms can be used. The
>> disadvantages are that the MPI all-to-all can be expensive and the number
>> of nodes is limited by the number of points in the z direction.
>> 2. Distribute the data in x-y only and use petsc to do matrix solves in
>> the x-y plane across nodes. The data would always be contiguous in z. The
>> possible disadvantage is that the x-y plane matrix solves could be slower.
>> However, there is no need for an all-to-all and the number of nodes is
>> roughly limited by nx*ny instead of nz.
>> The size of the grid will be about 1000 x 100 x 500 in x, y, and z, so
>> matrices would be about 100,000 x 100,000, but the grid size could vary.
>> For anyone interested, the derivatives in x and y are done with compact
>> finite differences, and in z with discrete Fourier transforms. I also hope
>> to make use petsc4py and python.
> Are the problems in the x-y planes linear or nonlinear? Are the
> coefficients the same in each level? What equations are being solved in
> this direction? (You can do much better than "banded" solvers, ala LAPACK,
> for these plane problems, but the best methods will depend on the problem.
> Fortunately, you can don't have to change the code to change the method.)
> About how many processes would you like to run this problem size on? Since
> the Fourier direction is densely coupled, it would be convenient to keep it
> local, but it's probably worth partitioning if your desired subdomain sizes
> get very small.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111115/fa5ea81b/attachment.htm>
