[petsc-users] Petsc Options
Cody Permann codypermann at gmail.com
Mon Nov 14 20:55:51 CST 2011
Perfect that will work for me.
Cody
On Mon, Nov 14, 2011 at 7:11 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>  I have added to petsc-dev the following
> #undef __FUNCT__
> #define __FUNCT__ "PetscOptionsUsed"
> /*@C
>   PetscOptionsUsed - Indicates if PETSc has used a particular option set
> in the database
>   Not Collective
>   Input Parameter:
> .    option - string name of option
>   Output Parameter:
> .   used - PETSC_TRUE if the option was used, otherwise false, including
> if option was not found in options database
>   Level: advanced
> .seealso: PetscOptionsView(), PetscOptionsLeft(), PetscOptionsAllUsed()
> PetscErrorCode  PetscOptionsUsed(const char *option,PetscBool *used)
>  PetscInt       i;
>  PetscErrorCode ierr;
>  PetscFunctionBegin;
>  *used = PETSC_FALSE;
>  for (i=0; i<options->N; i++) {
>    ierr = PetscStrcmp(options->names[i],option,used);CHKERRQ(ierr);
>    if (*used) {
>      *used = options->used[i];
>      break;
>  PetscFunctionReturn(0);
> On Nov 14, 2011, at 5:06 PM, Cody Permann wrote:
> > On Nov 14, 2011, at 2:20 PM, Matthew Knepley wrote:
> >> On Mon, Nov 14, 2011 at 9:16 PM, Cody Permann <codypermann at gmail.com>
> wrote:
> >> How about a function that would fill in a char *[] with the options
> used or a function that would return a boolean for a single option
> indicating whether it was used or not?  Basically we just need a public way
> to get at the data in PetscOptionTable::used.
> >> I don't like the whole table of options used, and we definitely need
> PetscOptionsOptionUsed(). What about providing
> >> the number of options, and an array of all option names?
> > That will work fine.  Anything is better than what we have now ;)
> >>    Matt
> >> Thanks,
> >> Cody
> >> On Nov 14, 2011, at 12:41 PM, Barry Smith wrote:
> >> >  Cody,
> >> >    What would you like the API to look like?
> >> >   Barry
> >> > On Nov 14, 2011, at 1:39 PM, Cody Permann wrote:
> >> >> There doesn't appear to be an API in PETSc for getting back the
> command line options "used" or "unused" for a simulation.  Yes I am aware
> that the options unused can be printed but there doesn't appear to be a
> mechanism for returning them back through a function call.  I'd like to add
> an option to MOOSE that would work like PETSc's "-options_left" CLI
> argument, but in order to do so I need to combine the options recognized
> for both libraries to report the global unused list.  Right now both MOOSE
> and PETSc have full access to the raw ARGV vector and each library
> recognizes it's own options and ignores the rest.
> >> >> I could strip out the options from ARGV before passing it to PETSc
> in conjunction with "-options_left" but that doesn't give me quite as much
> flexibility as I'd like.  It looks like there are about two dozen or so
> PETSc related options functions in the API but none of them return unused
> options, or otherwise allow me to query whether any particular option was
> recognized or not.  Is this assumption correct?
> >> >> Thanks,
> >> >> Cody
> >> What most experimenters take for granted before they begin their
> experiments lead.
> >> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111114/48b3f551/attachment.htm>
