[petsc-users] questions
Barry Smith
bsmith at mcs.anl.gov
Sun Nov 13 17:28:29 CST 2011
I added info to the manual page for DMDASetLocalFunction().
On Nov 11, 2011, at 12:13 PM, Matthew Knepley wrote:
> On Fri, Nov 11, 2011 at 6:06 PM, xiaohl <xiaohl at ices.utexas.edu> wrote:
> Hi
> I am going to use user defined context for this function call
> DMDASetLocalFunction(da,(DMDALocalFunction1) FormFunctionLocal);
> But How can I pass the "ctx" to the function FormFunctionLocal;
> PetscErrorCode FormFunctionLocal(DMDALocalInfo *info, PetscScalar ***u,
> PetscScalar ***f, void * ctx){
> I look at the example
> /petsc-3.2-p2/src/snes/examples/tutorials/ex19.c.html
> I think you intialize the "user" context by
> DMMGCreate(comm,nlevels,&user,&dmmg);
> for DMMG
> Do you have the similar routine for DMDA?
> If you use SNES, then you can pass it as the last argument to
> http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-dev/docs/manualpages/SNES/SNESSetFunction.html
> If you use SNESetDM() which sets this automatically, then it will use the one given to
> http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-dev/docs/manualpages/DM/DMSetApplicationContext.html
> Barry: Where should this be documented?
> Matt
> Hailong
> On Wed, 2 Nov 2011 15:53:27 -0500, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Nov 2, 2011, at 3:42 PM, Matthew Knepley wrote:
> On Wed, Nov 2, 2011 at 8:38 PM, xiaohl <xiaohl at ices.utexas.edu> wrote:
> Hi
> I am going to implement cell center difference method for
> u = - K grad p
> div u = f
> where p is the pressure , u is the velocity, f is the source term.
> my goal is to assemble the matrix and test the performance of different linear solvers in parallel.
> my question is how can I read the input file for K where K is n*n tensor.
> MatLoad()
> Hm, I think you should use a DMDA with n*n size dof and then use
> VecLoad() to load the entries of K.
> Barry
> second one is that do you have any similar examples?
> Nothing with the mixed-discretization of the Laplacian.
> Matt
> Hailong
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> -- Norbert Wiener
